Home > For Sale & Wanted > Sale of the century....
McS
I've just cleared out a mate's workshop of all his spares and surplus parts and its all up for grabs
So, here's how this is going to work... If you like the look of something, phone, text or PM me with an offer - I dont get offended, if it's not enough I'll tell you, but if it seems reasonable then we'll have a deal. Postage is possible on most items but collection/forum relay/meeting up is obviously preferable; all items are located in Basingstoke but could be moved to Camberley. Pictures are available and can be posted/emailed on request, I'm scared that I'd crash the server if I posted them all...
That all seems straight forward enough, so here we go, in no particular order....
- Rover SD1 3.5 V8 race engine, formerly owned by Mike Wolfe, c/w tubular manifolds, smooth box LT85 and LT230
- [s]ARB RD56 24 spline locker, in full working order when removed[/s]
- [s]ARB air compressor and loom, in full working order when removed[/s]
- North offroad Extreme wing kit, c/w front panels, sides and arches (well used), chequer plate tops and inner arches
- D44 competition 8274 bumper and steering gaurd, cranked to suit extreme wings, c/w 8274 guard/cage
- [s]ARB winch bumper, used but good condition, c/w D44 ground anchor mount[/s]
- [s]Southdown 8274 winch bumper, very good condition, slight bend in nearside wing (easily straightened)[/s]
- 2 x King 2" air shocks, 16" travel, as new condition
- 4 x King 2.5" air shocks, 12" travel, as new condition, still boxed
- [s]Kenlowe fan wiring loom and relay, as new condition[/s]
- Set of 4 genuine Icelandic spec Defender arches and rubber inners, new and unused
- 2 x 300tdi radiators, good condition
- Good used 300tdi intercooler
- Good used Td5 intercooler
- 2 x unknown oil coolers
- [s]Allisport uprated Td5 intercooler, good condition[/s]
- [s]Warn winch control (5 pin), new and unused[/s]
- [s]4ft Hi Lift jack, new and unused[/s]
- 2 x 4ft Farm Jack, used but in GWO
- [s]Gwyn Lewis stump hook, as new[/s]
- Clamp on diff gaurd
- QT front diff guard, new and unused
- Rear wrap around diff guard
- Autobox selector
- [s]Ashcroft Defender autobox console and auto box shifter, not perfect but in good order[/s]
- Td5 auto flex plate, ideal for converting your Td5 to auto
- Southdown Defender Tdi fuel tank guard, used but straight
- Defender 300tdi fuel tank, converted to take Td5 fuel pump, ideal for Td5 trayback conversion!
- Custom defender rear x member with 8274 winch tray
- North offroad tray back kit, includes wings and rear stays, setup for coilovers/air shocks, c/w chequer plate panels
- [s]2 x D44 ground anchors with removable spades, good condition[/s]
- [s]D44 ground anchor mount for front bumper, very good condition[/s]
- the worlds biggest ally fairlead, used but plenty of life left
- 4 x OEM 3.54 R&Ps, all in excellent condition
- 300tdi turbo and manifold, only removed to fit VVT
- unique jerry can based fuel tank, complete with feed and return hoses and fuel pump
- [s]1 pair D44 front shock turrets and relocation cones, very good condition[/s]
- 1 pair D44 rear relocation cones
- 1 pair Terrafirma 1" bump stop spacers, used but good condition
- [s]Pair of Terrafirma TF019 defender rear springs, fitted but never used, still boxed[/s]
- [s]Pair of Terrafirma TF130 Big Bore defender rear shocks, fitted but never used, still boxed[/s]
- 300tdi air filter (outer), new and unused
- Defender 90 pickup tonneau cover, designed to fit around a rear cage and stays, good condition
- Defender wing plastic grills, 5 x top left, 5 x top right, 1 x RHS, all in good condition.
- Series 3 brake servo c/w twin circuit master cylinder
- Oil pressure guage and sender unit
- 18 x Alloy wheels nuts
- [s]2 pairs of early 110 Alloy door tops with double sliding windows, excellent condition[/s]
- pair of lightweight door bottoms, absolutely mint frames, skins have seen some use, perfect for reskinning....
- lightweight bonnet, has seen some use but generally good condition
- Pair of QT race seats c/w 3 point harnesses and padding, good condition
- 4 x Compmotive alloys, 7 x 16, generally good condition
- pair of Defender outer wing skins, good condition, offside notched for roll cage hoop
- Td5 Defender ABS module c/w master cylinder
and breathe....
Ross
0780 3262299 The Scotia Winch Challenge
Post #39822 4th Sep 2010 11:00pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
crickey........what a list.
might have a home for a 300tdi radiator. can you confirm it will fit a 1995 defender?
thanks BM52
Post #39826 4th Sep 2010 11:21pm
McS
provided its a 1995 defender fitted with a 300tdi engine, yes it will Thumbs Up
Ross The Scotia Winch Challenge
Post #39827 4th Sep 2010 11:44pm
AfterHouR
Pm'd you re: the Terrafirma's
Regards
AfterHouR
Post #39857 5th Sep 2010 2:02pm
bm52
Ross
Great, i'll mention it to my mate. get back to you ASAP.
Cheers BM52
Post #39859 5th Sep 2010 2:15pm
landy
pm you regarding the allisport td5 intercooler and the 4ft hi lift jack Thumbs Up
Post #39873 5th Sep 2010 5:02pm
landy andy
How much for the rear locker, and compressor.
Thanks
Andy
Post #39976 6th Sep 2010 7:48pm
McS
Sorry mate they're sold.
Post #40011 6th Sep 2010 10:22pm
walfy
Nudge nudge
Oil cooler Whistle Whistle 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #40116 7th Sep 2010 8:58pm
