Home > Puma (Tdci) > Foglight switch for rear wok light
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I've got a foglight swith I'd like to use as a rear light switch. Anyone done this before? Need a wiring diagram.
Post #397704 10th Feb 2015 8:02pm
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
Marius,
Try here you might find one:
https://onedrive.live.com/?cid=4BC2D89C85C...C171%21551 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #397817 11th Feb 2015 9:03am
Venomator
Is this...
...the sort of thing you had in mind... Whistle
Sorry, just couldn't resist... Rolling with laughter  Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #397821 11th Feb 2015 10:00am
x-isle
I didn't use a fog light switch, but here is a 2 way diagram that did when I put mine in. Rocker switch on dash and rocker switch inside rear door. If you are just using one switch, you can just imagine the diagram without the 2nd switch and all is the same. I mounted the relay behind the rear right speaker panel where the "Purple" and "Black" wires can be found providing permanent live.
However, if you are using a standard Fog Light switch, I believe these are the pin-outs for the switch;
(The switch connects the earth feed, hence 2 Earth connections)
Pin 1: Earth (incoming) from relay (Pin 85 on the above diagram)
Pin 2: Bulb (Dash lights) - connect into feed of dash lights from the other switches.
Pin 3: Earth (outgoing) connect to a ground point
Pin 4: Not used.
Pin 5: "On" light - This is the same as the Dash Warning light shown on the diagram.
For more photos, take a look at the last but one post in this topic - http://www.defender2.net/forum/topic7022-15.html Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #397854 11th Feb 2015 12:04pm
Marius
Ok, so if I understand correctly it would be something like this:
Post #398418 13th Feb 2015 12:38pm
x-isle
As far as I'm aware, that's spot on! Thumbs Up
If I've got the pin outs on the switch wrong, it won't damage anything, but might be a case of trial and error. However, I'm 95% certain I've got it right
EDIT: I can't remember if the standard Rear Fog Light switch is a clicky one or momentary switch? If it isn't a clicky one, then you can't use it for the rear light.......... Craig Rogers
2007 Puma 110 XS
Post #398419 13th Feb 2015 12:41pm
x-isle
CAN'T BE DONE!!!!!!
I just went and checked (you can tell how often I used my rear fog light).
The switch is indeed a momentary switch which means it doesn't control the fog light, it will be controlled elsewhere, probably by the ECU depending on headlight conditions.
What this means is if you use it to control your work light it will only work if you held down the button, when you release the button the light will go back out as it doesn't click into place. Craig Rogers
2007 Puma 110 XS
Post #398423 13th Feb 2015 12:53pm
Marius
Yes it's not a click switch.....Sad damm
Post #398441 13th Feb 2015 1:53pm
Martin
Site Admin
Buy a cheap latching switch [ heated seat ~£8 ] and swap the button over?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #398443 13th Feb 2015 2:05pm
x-isle
^^ Good idea! Thumbs Up
Suspect the pin outs will probably be similar too. Craig Rogers
2007 Puma 110 XS
Post #398444 13th Feb 2015 2:12pm
landy andy
Yep that's what I did. I used a heated rear window switch, and swapped front.
Andy
Post #398445 13th Feb 2015 2:14pm
Martin
Site Admin
Heated seat switch is:
1 +ve IN
2 Illumination
3 not connected
4 +ve OUT
5 Earth
The LED is connected internally across +ve out and earth so it illuminates itself Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #398446 13th Feb 2015 2:15pm
x-isle
Thumbs Up It seems like it's the same then as the switch will probably work as an earth switch too.
Pins 3 & 4 probably do the same, I know on the fog light switch that Pin 4 works the same as Pin 3 even though it's not used.
The only thing is, will the LED still light? Craig Rogers
2007 Puma 110 XS
Post #398448 13th Feb 2015 2:20pm
Martin
Site Admin
Note that the heated seat and rear heated screen switches are positive side switching, to illuminate their own internal status LED.
This would require a change to the wiring diagrams.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #398449 13th Feb 2015 2:20pm
x-isle
aha, and there you go.
Just need to move the switch to the other side of the relay, feeding 86 Craig Rogers
2007 Puma 110 XS
Post #398451 13th Feb 2015 2:23pm
