![]() | Home > Puma (Tdci) > economy |
| harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309
I do 26mpg, if I want economy I'll get a Mondeo/Insignia diesel ;/)
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Pretty good, depending on the load in your truck and mileage. With a roofrack on, my avg consumption is hovering around 10.5-11l/100km, but it only has 10000km on the clock. Once can expect things to loosen up and consumption to go down marginally in the long run. I also add 2-stroke oil with every 2nd tank, which helps lubricate stuffs and I change the oil every 10Kkm. |
| hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 |
[quote="bpman"]i just refilled my 110 tdci and the light cam on at 642km, and it cost 114chf's to refill, what do you get on a tank to the bing/yellow refill light?
I think this works out as ... 114chf divided by 1.70chf/litre = 67 litres 9.58 litres per 100/km.... is that good or bad ???[/quote] Did you use a swiss calculator for that? :whistle: I calculeted roughly 10.5 litres per 100km -- that turns out to be the average consumption for a 110. |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Hornet... not sure what you mean.
I travelled 642km = distance I added 67 litres (which cost 114chf) = volume to calculate the consumption, divide the distance by the volume... 642 divided by 67 = 9.58 What's special about a Swiss calculator |
| o4dn Member Since: 08 Jan 2010 Location: South West Posts: 601
You have it wrong, it's 67 (volume) divided by 6.42 (distance) = 10.4361370717 l/100km |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Puma 110 station wagon, last check-61.19 litres (13.49 gallons), 396.5 miles =29.4 mpg. 1982 88" 2.25 diesel
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
Thats good
I just filled mine up......65.5lts by 4.546 = 14.4 gals and did 334 mile which gives 23.19. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Since April of this year I have covered just over 5000 miles in my 90 and refuelled 17 times! My severest economy was 26.73 MPG and my best 31.65 MPG. No map on for a significant time of that but back on now and of late been getting about 28 MPG on average last four fills!
Got no reason to complain me! Treat every day as if it is your last....one day you will be right!! |
I think a lot of it is down to the extra weight of the 110 and the roof rack must take 2 miles off the gallon.
If I could avarage more or even the same as all my other Defenders I would be happier but I suppose it is all part of owning a land rover. |
| Markh Member Since: 24 Jul 2010 Location: Grantham Posts: 33
I've got a 110 xs, new end of March, done nearly 10k miles. I've averaged 28.5 over that distance my best being 31 mpg. Normally don't run with roof bars etc. On holiday at mo with bars and a roof box and mpg gone down to about 26... "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
| pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456
i did 739 km and i refilled my 110 with 70,6 lt x 1,21euro = 85,4 euro
9.55 litres per 100km www.newfoundland.gr |
| totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
Mine is 9.3 KM per liter average mostly city driving w light foot. Im running BFG km1 33" MT tires.
| jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149
I constantly travel between London and Gibraltar loaded up through Spain and end up averaging 32-34 mpg. But then my truck is a 90!!
El pepe flamenco JLS 'El Pepe Flamenco' |
Mine is a 90 too...Thought I was doing well, those are very impressive figures considering you're loaded up too! Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
