![]() | Home > Td5 > Bench testing MAF |
PM Pete from Bell Auto Services he has tested and even did a trial whereupon he provided certain forum members new ones for their old. If it can be tested he will know expected readings and how to obtain them.
![]() Treat every day as if it is your last....one day you will be right!! |
On the bas site under maf it explains how to check with a multimeter
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Cool cheers. Off to have a look. 1999 Defender TD5 110
Found it
https://secure.bellautoservices.co.uk/store/td5-air-flow-meter/ So, I assume I leave the plug connected but find a method of connecting the meter from Pin2 to ground? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Well after sticking a bit of wire into the pin 2 and putting the plug back on, I checked the voltage and I thought I was getting 2v, but after doing two more tests, I was getting Mv readings! 1999 Defender TD5 110
What's the next plan, clean or replace? If you go through life with your head in the sand....all people will see is an ar5e!!
Replace I think. While at BAS HQ I had the MAF on already tested and purchased two more from the forum.
One was dead so that got binned. The left over one, was put on as it was reading slightly higher but not as high as it should be. (thats the one on now) So I think its time for a new one. Seen a few knocking around on Ebay etc for around £40 ish. But I think I am leaning towards one from LR/BAS etc. A mate works in a motor factors so can get them but the make is one I have not heard of! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Give Pete a tinkle or drop him a 'pm.' With all the testing he's done on them he'll know which one comes out on top. In the interim whip it out and if it looks bad try a clean and retake your readings perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
I do have a look at the MAF, it did look OK but looks can be deceiving.
A clean might be an option, I only have brake cleaner so some electrical contract cleaner would be better. Re-testing might also be worth while. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Brake cleaner will be ok. Give it a rinse in white spirits after and let it dry a while. Worth a shot on a Sunday when everything is shut.
May be worth a look.... This one first.... http://www.landyzone.co.uk/lz/f7/maf-senso...11016.html Then.... http://www.landyzone.co.uk/lz/f67/removing...98286.html ![]() Treat every day as if it is your last....one day you will be right!! |
Thanks K9F. I will give the MAP and AAP a clean as well. Another thought is to clean out the intercooler.(but does not effect the MAF as far I can tell) 1999 Defender TD5 110
MAF replaced and now 1.9xx volts at pin 2
![]() Regards John M0VAZ Econet Station 48 no clock |
![]() Ray |
Indeed Ray. Lets see what the MPG is like on my next long trip and the runs to and from work 1999 Defender TD5 110
