![]() | Home > Puma (Tdci) > Faultmate - Fuel pump calibration and injector learn failure |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Looking at the screenshot you are running version 1.29 of VE. V1.33 is the latest version so I would update the server modules to V1.33 and try again.
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Ahh old firmware
![]() Pete |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
apologies ... I used someone else's screenshot of the error. I am using the latest firmware. 2008 Defender 110 XS SW - M57N2 / 8HP70X
I found that the PCL cycle would not complete when using Internet Explorer 8 or newer. I then used my other laptop running IE7 and the cycle completed. Also physically check that module SM133 is showing V 1.33 on the MSV firmware.
I'm using a MacBook Pro with a parallels instance of xp 64bit and ie6. I'm thinking I may need to run from a PC directly. I may have to invest in an old toughbook. 2008 Defender 110 XS SW - M57N2 / 8HP70X
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17918 ![]() ![]() ![]() |
I too have had issues with pump cal using faultmate which I've never really got to the bottom of. I can't remember the exact fault message (similar to the screenshot above though), but although faultmate threw up the error the pump cal was successfully done.
I've also found that usually after doing the pump cal apparently successfully the "pump calibration not carried out" DTC will appear and need clearing two or three times (but without doing the cal again). It all seems a bit unpredictable and unstisfactory, and I would dearly like to know how the process really works and what the ECU software is actually doing. |
Try installing windows via bootcamp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
I got rid of my faultmate hated it and very expensive if you need to cover many models. The guy Chris?! talks a good game but the customer service was terrible i had errors like this on a weekly basis that would make you pull your hair out
