![]() | Home > Maintenance & Modifications > Crystals or Xenons? |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Led are better still
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
/\ as above
celticpilgrim Member Since: 23 Nov 2014 Location: Wiltshire Posts: 26 ![]() ![]() ![]() |
I know, but they are a lot more expensive...
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Crystals with decent bulbs and maybe the relay mod, best output for money. Xenon retrofits are illegal end of
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Cheers, Grafty, thanks for the heads up
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Has anyone tried the relay mod on a Puma? |
Now HID Xenon as a kit form are illegal as no type approval.
HID xenon headlights which are E marked are only road legal if vehicle is fitted with self levelling and wash wipe facility. Therefore are illegal to be fitted to a Defender unless you go to the expense of fitting self levelling etc. Now these Xenon bulbs, are they true HID Xenon or are they just Xenon filled bulbs? Does an E marked Xenon bulb fitted into a headlight unit type approved for Xenon bulb need self levelling or wash wipe facility? Brendan |
Official VOSA advice
https://mattersoftesting.blog.gov.uk/vosas...questions/ Do HID headlamps require washers / self levellers? Headlamp washing and levelling systems are a legal requirement for high intensity discharge (HID) lamps with a luminous intensity exceeding 2,000 lumens. But unless the luminous intensity is marked on the lamp, a tester won’t be able to tell if these systems are needed. So, they can only be rejected if they are fitted and are inoperative or obviously defective. If they are missing and you believe they should be fitted, then pass and advise. |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I seam to remember a xenon lights on the dealer option list when I ordered?
I had zenons on my disco and it passed mot no worries
They can cause radio interference
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 ![]() ![]() ![]() |
Has anyone tried this upgrade relay kit? Price seems reasonable.
http://www.paddockspares.com/boomslang-per...-loom.html |
I think they were bulbs only? |
^^ Correct, they are H4 bulbs only. Part number is VPLDV0061. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
