Home > Maintenance & Modifications > Crystals or Xenons?
celticpilgrim
United Kingdom 2007 Defender 90 Puma 2.4 HT Java Black
Crystals or Xenons?
Ho folks, thinking of upgrading the lights on the Puma, and could use some advice. Which would be better to fit - Crystals or Xenons? I'm looking on Flatdogs website and both are reasonable, but which are best - any advice most welcome.
Cheers,
CP
Post #393891 29th Jan 2015 11:18pm
bear100
Led are better still
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #393896 29th Jan 2015 11:23pm
JAY BOY
Wales
/\ as above Thumbs Up
Post #393897 29th Jan 2015 11:24pm
celticpilgrim
I know, but they are a lot more expensive...
Post #393905 29th Jan 2015 11:37pm
grafty99
Crystals with decent bulbs and maybe the relay mod, best output for money. Xenon retrofits are illegal end of Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #393906 29th Jan 2015 11:39pm
celticpilgrim
Cheers, Grafty, thanks for the heads up
Post #393917 30th Jan 2015 12:03am
driver9
Has anyone tried the relay mod on a Puma?
Post #393960 30th Jan 2015 9:12am
leeds
Now HID Xenon as a kit form are illegal as no type approval.
HID xenon headlights which are E marked are only road legal if vehicle is fitted with self levelling and wash wipe facility. Therefore are illegal to be fitted to a Defender unless you go to the expense of fitting self levelling etc.
Now these Xenon bulbs, are they true HID Xenon or are they just Xenon filled bulbs?
Does an E marked Xenon bulb fitted into a headlight unit type approved for Xenon bulb need self levelling or wash wipe facility?
Brendan
Post #393968 30th Jan 2015 10:04am
Official VOSA advice
https://mattersoftesting.blog.gov.uk/vosas...questions/
Do HID headlamps require washers / self levellers?
Headlamp washing and levelling systems are a legal requirement for high intensity discharge (HID) lamps with a luminous intensity exceeding 2,000 lumens. But unless the luminous intensity is marked on the lamp, a tester won’t be able to tell if these systems are needed.
So, they can only be rejected if they are fitted and are inoperative or obviously defective. If they are missing and you believe they should be fitted, then pass and advise.
Post #394026 30th Jan 2015 12:58pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I seam to remember a xenon lights on the dealer option list when I ordered?
Post #394166 30th Jan 2015 8:58pm
I had zenons on my disco and it passed mot no worries
Post #394167 30th Jan 2015 9:02pm
They can cause radio interference
Post #394168 30th Jan 2015 9:02pm
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Boomslang
Has anyone tried this upgrade relay kit? Price seems reasonable.
http://www.paddockspares.com/boomslang-per...-loom.html
Post #394200 30th Jan 2015 10:02pm
I think they were bulbs only?
Post #394204 30th Jan 2015 10:10pm
ericvv
Post #394290 31st Jan 2015 5:34am
