![]() | Home > Maintenance & Modifications > Puma engine cover removal. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6035 ![]() ![]() |
As you say, two bolts top front, and peg that locates in hole at rear. To remove, undo bolts, lift front, push back, lift off
Andy |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617 ![]() ![]() ![]() |
Thanks Andy
![]() I just wanted to make sure that the rear 'locator' disc thing wasn't a bolt or clip or anything before just yanking it off. Does that disc serve any other purpose than the location of the cover? ![]() Click image to enlarge So i've put it back on by locating the to front bolts and firmly thumping the rear of the cover to locate the disc? |
