Home > Maintenance & Modifications > Defender diagnostics and software?
Crafty1980
So... I had to call out LR assist earlier in the week to sort out an issue which turned out to be a faulty steering angle sensor... To diagnose, he plugged in a laptop to a socket under the dash.
I'm guessing that software/hardware is a closely guarded item as far as LR is concerned... So does anyone know where I can get a copy and buy the hardware lead? Smile
...or are there other equal products on the market? Much like the RossTech VAG-COM system for Audis/VWs etc...
B
Post #391354 22nd Jan 2015 10:22am
landy andy
"faulty steering angle sensor."
On a Defender? I didn't think there was such a thing on a Defender.
There are a few systems on the market depending how much you want to spend, and what model (engine) you've got.
Andy
Post #391428 22nd Jan 2015 1:17pm
TJ101
Andy
For 2015 MY Steering angle sensor for the DSC system !!
Yep, been there, was not faulty ? as such, just needed to be re calibrated,,
Unless you want to spend loads, you will not be able to play with the vehicle's software,, a cheap scangauge will be able to read and reset simple trouble codes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391433 22nd Jan 2015 1:24pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
There's the normal:
Blackbox Nanocom
Britpart Lynx
Bearmach Hawkeye
Terrfirma (iCarSoft thing which isn't all that intuitive unless you just want error codes)
I know the LR system for the TD5 and previous was the Testbook, which will set you back 4 figures. The Nanocom can do most of it though.
For the Puma's, there's plenty of rip-off/copy units floating around on some of the Chinese OBD sites. There's also a Mongoose cable I believe which is a home brew system to. Designed to talk to later (OBD protocol) defenders.
There's the SmartGauge and UltraGauge system to which is good for codes and live stream data.
I also have a Delphi clone system which is pretty good. Gets a good chunk of info from the TD5's and can cover a good 60-70% of Puma stuff. Great for live recording and playing back using charts and tables. I also have the Nanocom with Def TD5, Disco TD5 and Def Puma and it's a lovely easy system!
Post #391436 22nd Jan 2015 1:27pm
Don't forget also on the list is Faultmate from Black Box, which has most of the capabilities of the genuine item (and more than Nanocom).
Post #391439 22nd Jan 2015 1:31pm
taazzukcb
Yeah, FaultMate is good to. Though I dont think this is sold anymore, unless one comes up on eBay?
BlackBox just said to get the Nanocom when I asked basically.
The Puma's can also put out a good amount of info through the Bluetooth OBD modules and aps like TorquePro etc etc. Great for leaving them plugged in permanently if you're into that kind'a thing Smile.
Think the new system is JLR SDD/IDS? Something like that! No good for TD5 though!
Post #391441 22nd Jan 2015 1:33pm
landy andy
Oh my god, more electronics to go wrong. Big Cry Big Cry Big Cry Big Cry
Andy
Post #391443 22nd Jan 2015 1:34pm
Crafty1980
Whether it's faulty or just needs calibrating, LR still have my defender and it's been over a week now! Christ knows what they're doing to it!!
In the meantime, I'm still driving around in their £65k Discovery HSE loan car! It's a bit too comfortable...
Cheers for the info/advice about the gear though! Will look into it...
Post #391445 22nd Jan 2015 1:40pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Black box are still selling Faultmate. My Faultmate MSV-2 arrived this morning from them Thumbs Up 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #391538 22nd Jan 2015 8:13pm
taazzukcb
Hmm... Damn! I was almost positive they said to me they were discontinuing the faultmate. That's what I was after over the nanocom.
Ah well. Might just have to expand the kit one day just to try one :p! Unless I can find an uber cheap T4!
Post #391543 22nd Jan 2015 8:33pm
GUM97
Currently using SDD. It'll cost you upwards of £8k for one unit, and you'll have to jump through hoops to prove that you're entitled to use it. An engine to TDi for!
Post #391550 22nd Jan 2015 8:50pm
taazzukcb
There are clones around that do work rather well.
Post #391558 22nd Jan 2015 9:15pm
