Home > Td5 > No front wipers ... in deepest Switzerland
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
So here I am with T3, my 2005 90 van in the middle of the mountains.
This morning the front windscreen wipers failed instantly and totally in vertical position, all switch settings. Crying or Very sad
There was a single noise clunk / bang but engine was running so - not much to hear!
The rear wiper still works. Other electrics work.
This is basic van model, so first q is... fuse, motor, relays, switch? Question
And how to diagnose with limited tools/ access. (Garages here are 200 swiss bucks an hour..)
Is front wiper on it's own fuse? Is there a relay and can it 'blow'?
(Please don't say motor...!)
Thanks Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #390088 19th Jan 2015 8:36am
landy andy
Yes front wiper has it's own fuse. And rear one is different one
From memory the fuse also controls the washer, so if your washer motor works, the fuse is ok, and you'll probably hear the relay click for the wipe.
I think you will find that you motor has blown of gearbox has gone, due to blades being frozen to screen unable to move then motor kicking in.
Sorry
On the good side if yours is basic spec, you haven't got air con, so is easier to fix Thumbs Up
Andy
Post #390091 19th Jan 2015 8:53am
ppad
Hmm thanks! Washers were frozen this morning, not enough anti freeze what I last topped up.
I've got a Haynes manual here, it seems to say under seat fusebox (#5) and passenger fusebox (#9) for the fuses
.. it's that nasty clunk I also heard ... Whistle
Um., the motor is a front dash removal job? Sold the much modified 110 2.8, in Oz
Post #390094 19th Jan 2015 9:04am
The wipers can lock due to wear in the wheelboxes and rack (mine locked mid-wipe not long ago for this reason). Try waggling each wipet by hand, there should be a little play in both, at least it should be apparent that they're not locked solid. You may find that one clicks and then they wipe again. Remember that if they have jammed the motor will be live and trying to park them all the time the ignition is on. Although there is (apparently) thermal protection on the motor it is likely that prolonged running in this state will cause collateral damage.
If this does turn out to be the problem a short term fix is to remove the motor, extract the drive rack, and adjust the wheelboxes so a different part of the gear is in use. The permanent fix (new rack and wheelboxes) should be done as soon as possible and requires removal of the dash in a Puma. It took me about 4 hours a few werks ago to do mine, but I have had a lot of experience removing the dash.
Edit - just noticed you have a Td5 which makes the job easier as far as I know.
Post #390148 19th Jan 2015 12:02pm
ppad
Thanks for that also
Fiddle around at lunchtime and wiper fuse is a) blown and b) 10A not 15A So... cheap answer yippee
No doubt previous owner considered 10A plenty for that service, and normally, yes.
Today's lessons: check the easy stuff first .. and in general, follow Land Rover manual... Thumbs Up Sold the much modified 110 2.8, in Oz
Post #390203 19th Jan 2015 3:21pm
landy andy
Wow. Lucky man.
Andy
Post #390204 19th Jan 2015 3:29pm
