adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
Had the same hearse back in October for my brother....but a smaller convoy Putting Dreams on Drives at JLR Solihull.. |
Outa curiosity which side/axle was it?? Back o/t,fitted Climair wind deflectors. Pov.spec,ftw. 2006, 110,TD5. |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Both sides of rear axle. Write up here http://www.defender2.net/forum/topic28138-105.html ![]() Self confessed mileage hunter ![]() |
Ah, right,thort you had the same problem I had removing f/n/s flange,I had to cut the f**ker off.
cheers Pov.spec,ftw. 2006, 110,TD5. |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Up till 2am this morning working on the 90.
Started with the rear pinion diff seal replacement, which turned into "ill just whip that silencer off and put the replacement pipe on" which then turned into "ill just take the cat off and give it some fettling". Some difference (sound, turbo lag and hopefully one less leak) although not the best of tasks to do all lying on the floor. Does anyone know if theres supposed to be an exhaust gasket at the rear of the mid silencer? The three bolt flange one? William |
Yeah,they sell a stainless jobbie,but to me it doesn't seem like it would be effective without a big blob of sealant anyways. Pov.spec,ftw. 2006, 110,TD5.
Rule#2 Pov.spec,ftw. 2006, 110,TD5.
OldhamLandy Member Since: 17 Oct 2013 Location: somewhere Posts: 164 ![]() ![]() ![]() |
Fitted my Entreq snow cowl in readiness for the copious amounts of snow forecasted
![]() 2014 Defender 90xs SW - Corris Grey with Santorini Black Roof |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
Pulled out the drive and the steering felt heavy like the power steering was not working.
Got 400yards down the road and decide all was not well. Flat N/S tyre ![]() Broke out the plug-in pump and started pumping the tyre up. After 10mins the tyre was no better. So decided to drive with caution to the garage around the corner. 11psi ![]() After filling with juice and queueing up I notice a chap in Jag taking an interest in my front tyre...Yup. You guessed, tyre leaking air ![]() So in the forecourt I changed the tyre.....So two things have come from this 1. I need a new plug-in tyre pump (the one I have now, might just be good enough for a bike tyre) 2. Its about time to buy two new BFG AT 235/85 16s 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Mac87 Member Since: 06 Nov 2013 Location: Kent Posts: 64 ![]() ![]() |
Swore at it for a while as drivers door lock was frozen solid. Cue getting into it on the passenger side and crawling across. Thawed out by the time i'd finished my journey luckily
SupraAyf Member Since: 08 Sep 2014 Location: Durham Posts: 142 ![]() ![]() ![]() |
Cleaned off the snow. That was it. NFTR
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 ![]() ![]() ![]() |
Fitted YRM seatbox corner protectors so it looks tidy now. Also replaced a bulb in my Wipac spotlights. Still waiting for an engineer from the insurance company to carry out an assessment of the roof damage. 2007 (57) Defender 90 (Sold)
Looking for another to replace it. The road less travelled.... is a muddy one! |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 ![]() ![]() ![]() |
After feeding the horses I took a little detour to town.
You see we are normally tight as ar*eholes in Yorkshire but we dont mind chipping in to buy some snow now and again. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The hill was a lot more slippery than I thought but I made it up, shame the Navara following me didnt ![]() 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
And...
Bought a Heritage HT... ![]() Well, deposit down, HT allocated, bunny = happy! ... ![]() YAY... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
