Home > Technical > Trailer Light flashing
Page 2 of 2 <12
bob neville
This is the RDX relay that works Thumbs Up
http://www.ebay.co.uk/itm/RDX-4-Pin-Flashe...5af941eb68
Open the fuse panel under the steering wheel and look at the top left hand relay. If one of these is already fitted then turn on the hazard lights and turn the adjuster until the trailer light just stops flashing - I thing it is anti clockwise ? Once the trailer light is not flashing turn off the hazards and try the indicators, the trailer light should now not flash at all.
2013 Defender 90 CSW - sold
Post #389341 17th Jan 2015 12:25pm
It is indeed a bulb check, the RDX relay is the only cure.
Post #389342 17th Jan 2015 12:25pm
CatherineF
Thanks guys, my guess is no one isn't fitted. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #389348 17th Jan 2015 12:42pm
K9F
Miserableolgit wrote:
Next question is does the vehicle have standard filament bulbs or LED's in the indicators?
Bow down Apologies Steve but I knew where you were headed on this one. A classic case of 'My fault your mistake!' Bow down Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #389351 17th Jan 2015 12:59pm
celticpilgrim
United Kingdom 2007 Defender 90 Puma 2.4 HT Java Black
Cheers, Bob. Just been out, popped the fuse cover and 30 seconds later, job done! Very Happy
Post #392374 25th Jan 2015 2:25pm
AndyW
United Kingdom 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Hi guys, new to the forum so please be kind! Very Happy
Just installing my RDX relay now, excuse my blonde moment but when you say "turn the knob until the trailer light stops flashing" - do you mean until the trailer light stays on or stays off?
Thanks in advance!
Post #520479 3rd Apr 2016 11:03am
mk1collector
With no trailer connected the trailer light should flash once when the indicators are switched on then not flash again Thumbs Up Ray
My build thread
Post #520482 3rd Apr 2016 11:07am
AndyW
Perfect, now all sorted, thanks for your help! Thumbs Up
Post #520505 3rd Apr 2016 1:24pm
mk1collector
Post #520506 3rd Apr 2016 1:25pm
Make sure you adjust it with engine running at full voltage, then it will be 100% accurate. Thumbs Up
Post #520507 3rd Apr 2016 1:36pm
Page 2 of 2 <12
