![]() | Home > Technical > Trailer Light flashing |
This is the RDX relay that works
![]() http://www.ebay.co.uk/itm/RDX-4-Pin-Flashe...5af941eb68 Open the fuse panel under the steering wheel and look at the top left hand relay. If one of these is already fitted then turn on the hazard lights and turn the adjuster until the trailer light just stops flashing - I thing it is anti clockwise ? Once the trailer light is not flashing turn off the hazards and try the indicators, the trailer light should now not flash at all. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
It is indeed a bulb check, the RDX relay is the only cure.
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
celticpilgrim Member Since: 23 Nov 2014 Location: Wiltshire Posts: 26 ![]() ![]() ![]() |
Cheers, Bob. Just been out, popped the fuse cover and 30 seconds later, job done!
AndyW Member Since: 01 Apr 2016 Location: Norfolk Posts: 4 ![]() ![]() ![]() |
Hi guys, new to the forum so please be kind!
![]() Just installing my RDX relay now, excuse my blonde moment but when you say "turn the knob until the trailer light stops flashing" - do you mean until the trailer light stays on or stays off? Thanks in advance! |
With no trailer connected the trailer light should flash once when the indicators are switched on then not flash again
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Perfect, now all sorted, thanks for your help!
Make sure you adjust it with engine running at full voltage, then it will be 100% accurate.
