![]() | Home > Maintenance & Modifications > Body wrapping Defender 90 |
Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52 ![]() ![]() ![]() |
Recently I bought a 90 for green laning and as a project to work on in the little spare time I have. The paint work needs a bit of attention and I would like to change the colour as there are various different coloured panels on her at the moment. However, I don't want pay a fortune on a complete respray just to scratch it up taking it through hedges and trees.
Based on this I was considering using a body wrap as I have heard good things about them. Has anyone had any experience with them, and if so would you recommend a brand or type. Also what is the rough cost and is it something you can do yourself or should you go to a specialist company. Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Send a PM to Ellebarto. I don't know whether he still has it on, but it looked a good job
paulnb57 Member Since: 18 May 2011 Location: Isle of Wight UK Posts: 38 ![]() |
Ellbarto removed it....
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
If it was me Id do like JimBob said get it nicely rubbed down and remove/ mask up as much as you can. As your local get a big can of Nato green or sand from Witham SV or your local paint supplier and brush/ roll it. Youll get a good enough finish for a land rover easily
I am trying to make my 90 one color too, but driving it has higher priority. I roll it with cheap paint. for less then 50 pounds I think I will have the 90 in one color. I am afraid however that parts might be damaged before it is painted completely.
![]() ![]() Click image to enlarge ![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
FTW! Pov.spec,ftw. 2006, 110,TD5. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2377 ![]() ![]() ![]() |
Coach paint from Turners, will last well, is designed to be brushable and rollable and they will mix whatever colour you want. Doesn't come out concours but reasonable finish and you won't cry when you drag it down a hedge
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
I used Dulux glosson a van once, came out quite well!
![]() 88" Series One Old Norton ![]() Minerva |
Sounds like a plan guys, a roller it will be when the time comes.
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Roller painting is always a winner. My ibex, before and after.
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
U pol raptor!
Hey Roel, where did you get roll cage that only covers the drivers side of the car? ![]() Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip Last edited by Shutts on 16th Jan 2015 1:02am. Edited 1 time in total |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I think top is pre fitting and below post fitting a rear only hoop as I can't see it through the window. Could be wrong though! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Shaggydog, added a smiley now just to say I was joking
![]() [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
