Home > Maintenance & Modifications > Body wrapping Defender 90
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
Recently I bought a 90 for green laning and as a project to work on in the little spare time I have. The paint work needs a bit of attention and I would like to change the colour as there are various different coloured panels on her at the moment. However, I don't want pay a fortune on a complete respray just to scratch it up taking it through hedges and trees.
Based on this I was considering using a body wrap as I have heard good things about them.
Has anyone had any experience with them, and if so would you recommend a brand or type. Also what is the rough cost and is it something you can do yourself or should you go to a specialist company.
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #388601 14th Jan 2015 11:36pm
jimbob7
Wrap can be a real nightmare to remove should it get tatty (which it will,quickly, if as you suggest, you "drive it thru hedges") or you get bored with it,buying highest quality (3m) wrap is your best bet. If it was me I'd sand the paintwork down and paint it with a roller,with a bit of practice you can get quite a good finish using satin finish also touching up any future marks will be a doddle. Pov.spec,ftw. 2006, 110,TD5.
Post #388613 15th Jan 2015 12:09am
smb
Send a PM to Ellebarto. I don't know whether he still has it on, but it looked a good job
Post #388619 15th Jan 2015 12:57am
paulnb57
Ellbarto removed it....
Post #388633 15th Jan 2015 7:56am
SailingTom
If it was me Id do like JimBob said get it nicely rubbed down and remove/ mask up as much as you can. As your local get a big can of Nato green or sand from Witham SV or your local paint supplier and brush/ roll it. Youll get a good enough finish for a land rover easily Thumbs Up Defender puma dormobile camper
Post #388649 15th Jan 2015 9:37am
roel
I am trying to make my 90 one color too, but driving it has higher priority. I roll it with cheap paint. for less then 50 pounds I think I will have the 90 in one color. I am afraid however that parts might be damaged before it is painted completely. Whistle
 Roel
2003 90 Td5 (2009-now)
Post #388655 15th Jan 2015 9:42am
jimbob7
FTW! Pov.spec,ftw. 2006, 110,TD5.
Post #388720 15th Jan 2015 2:30pm
Mo Murphy
Coach paint from Turners, will last well, is designed to be brushable and rollable and they will mix whatever colour you want. Doesn't come out concours but reasonable finish and you won't cry when you drag it down a hedge Smile mines been on 4 years now and just gets an annual touch up.
50 Shades of Pennine Grey
Post #388723 15th Jan 2015 2:54pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I used Dulux glosson a van once, came out quite well! Smile 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #388761 15th Jan 2015 5:22pm
Shutts
Sounds like a plan guys, a roller it will be when the time comes.
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #388778 15th Jan 2015 6:02pm
Roller painting is always a winner. My ibex, before and after.
Post #388838 15th Jan 2015 9:13pm
Leenorthants
U pol raptor!
Post #388854 15th Jan 2015 9:57pm
Shutts
Hey Roel, where did you get roll cage that only covers the drivers side of the car? Whistle
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #388901 15th Jan 2015 11:29pm
shaggydog
Shutts
I think top is pre fitting and below post fitting a rear only hoop as I can't see it through the window.
Could be wrong though! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #388913 16th Jan 2015 12:08am
Shutts
Shaggydog, added a smiley now just to say I was joking Thumbs Up |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #388921 16th Jan 2015 1:04am
