![]() | Home > In Car Electronics > Best way to run light bar cable through roof? |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Help can anyone give me some advice on the best way to run cable to a led light I want to mount on my roof rack. I would like to be vale to unplug light to remove roof rack from time to time. Any suggestions on water proof surface mount plugs and where to site it?
![]() Picture of what you have done would be great Thanks Andy |
Have a look on the mobilecentre website or call Tim, I bought a couple about Ł30 and made for marine environments
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2790 ![]() ![]() |
With regards to cable routing, if you don't want to drill your roof then you can always run a cable up the A pillar, through the door frame where the seal sticks on and then drill a hole through the gutter and go straight up through the gutter. Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
http://nakatanenga-tours.de/shop/article_A...ungen.html WANTED:
SII or SIII in max 1.5k |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17997 ![]() ![]() ![]() |
My preferred option is pretty much the same as Zone30's, ie to run a trunked cable down the outside of the RAI, through the gap between bonnet and wing, but I'd put a connector just under the bonnet.
It is tidy, doesn't require puncturing any body panels, and can be removed easily if the rack is to come off. |
+1, as in Zone30's post.
![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Ran my cables from the second battery along the rear tub, out the rear of the hard top, into a connector (from Mobilecentre) then along the roof rack to the LED lights..
I can remove the roof rack and lights with out any issues of water ingress. This is the connector to use mounted on the rear of the hardtop http://www.mobilecentre.co.uk/index.php?ma...mp;pID=701 2007 TD5 90 Hard Top |
