Home > In Car Electronics > Best way to run light bar cable through roof?
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Help can anyone give me some advice on the best way to run cable to a led light I want to mount on my roof rack. I would like to be vale to unplug light to remove roof rack from time to time. Any suggestions on water proof surface mount plugs and where to site it? Shocked
Picture of what you have done would be great
Thanks Andy
Post #387878 12th Jan 2015 11:15pm
Have a look on the mobilecentre website or call Tim, I bought a couple about �30 and made for marine environments
Post #387946 13th Jan 2015 8:15am
Cheshire110
With regards to cable routing, if you don't want to drill your roof then you can always run a cable up the A pillar, through the door frame where the seal sticks on and then drill a hole through the gutter and go straight up through the gutter. Cheers, David
Post #387975 13th Jan 2015 11:09am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Mine goes along the snorkel, between the gap under the bonnet, through the motorcompartment, underneath the car and through the plate under the cubbybox.
I.a.w. only a hole through that plate. No holes through roof!
Post #388006 13th Jan 2015 12:44pm
nakatanenga
Germany
Post #388023 13th Jan 2015 2:08pm
My preferred option is pretty much the same as Zone30's, ie to run a trunked cable down the outside of the RAI, through the gap between bonnet and wing, but I'd put a connector just under the bonnet.
It is tidy, doesn't require puncturing any body panels, and can be removed easily if the rack is to come off.
Post #388048 13th Jan 2015 3:22pm
VeeTee
Netherlands
+1, as in Zone30's post.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #388069 13th Jan 2015 6:12pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Ran my cables from the second battery along the rear tub, out the rear of the hard top, into a connector (from Mobilecentre) then along the roof rack to the LED lights..
I can remove the roof rack and lights with out any issues of water ingress.
This is the connector to use mounted on the rear of the hardtop http://www.mobilecentre.co.uk/index.php?ma...mp;pID=701 2007 TD5 90 Hard Top
Post #388586 14th Jan 2015 11:07pm
