![]() | Home > Puma (Tdci) > rear wheel arch inserts |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
l would like to know if anyone has bought or made some rear inner wheel arch mouldings to protect the inside of the wheel arch from mud, stones, salt - bit like the front wheel arch inserts on the front of a td5 or tdci?
the company entreq has just brought out these http://www.entreq.de/products/protection/r...leche.html but I'd like something that goes right around the inner arch but still allows articulation ... anyone seen anything or made their own ? |
| draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49
I always wondered if you could alter a set of the front liners, to fit the rear?
two good ideas...
I bought some 1.5mm thick plastic sheet and a rivnut tool ... I am also looking at other vehicles, range rover (with similar sized wheels), to see if they have liners that could be adapted. |
| dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609
Friend painted the inside of the guards with this stuff. Basically forms a plastic liner when hardened. Worked a treat.
http://www.rhino.net.au/ute-liner.html 110 2.4TDCi 110 300Tdi
LROCV ::: AULRO.com |
