![]() | Home > Puma (Tdci) > Doors warping |
some are worse than others it's the pressing for the handle which causes it 2.4 90 XS
Ear tiz:
Knew I'd seen it and bu99er me I found it this time: http://www.defender2.net/forum/topic3265.html?highlight=dents Happy days! ![]() Treat every day as if it is your last....one day you will be right!! |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
My 09 puma is the same and I think nearly all vehicles are.I fitted the new style steel door to my V8 90.They were perfect after spraying but as the handles were fitted,the large dent appeared.It's the handle that causes it,Landie phenomenon! Puma 110 SW
90 V8 SOFT TOP |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
probably ever thinner metal
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Ive straightened mine by taking the trim off the inside and glueing some plywood (dont laugh it's only tempoary) so it pushes the dents out. I found that the door handles were not the cause of the dents as I slakened mine off and they were still there. The passanger door is now perfect but the drivers door is still a mess, I am going to take the door off and place it on a flat surface so I can puch them out properly. 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
All cars have CURVED surfaces.
Defender has PLANE surfaces so, You can build the Defender doors with 3mm Birmabright or steel, but when you close a screw or a rivet/nut you'll note a bend surface Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Unpainted defender:
[img]http://www.landrover.com/imagery/global/nameplate/photos_and_video/wallpapers/defender/All_Explore_Wallpaper_L316_INT_Shell-850x425[/img] Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
as often said it's a Defender and as such................ 2.4 90 XS
Thats still knoking around The thinner the metal they use (and it has got that way) the worse it has become...probably not helped by steel doors that once werent! Mike |
