Home > Puma (Tdci) > Doors warping
BigMike
Doors warping
I'm sure I read a thread on here about this but can't find it. Both my drivers and passenger door are slightly warped under the handles. Its very obvious if you look down the veicle from either end, the panels kind of go in then out again.
The body shop guy at one dealership is telling me that they should be straight, and the body shop guy at the place my (2010) 90 is is saying its normal for them to be warped. I just called LR customer service, and they said its normal for them to be warped. Does anyone else have any experience of this?
Post #38648 20th Aug 2010 10:56am
Grockle
some are worse than others it's the pressing for the handle which causes it 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #38651 20th Aug 2010 11:03am
K9F
Ear tiz:
Knew I'd seen it and bu99er me I found it this time:
http://www.defender2.net/forum/topic3265.html?highlight=dents
Happy days! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38652 20th Aug 2010 11:06am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
My 09 puma is the same and I think nearly all vehicles are.I fitted the new style steel door to my V8 90.They were perfect after spraying but as the handles were fitted,the large dent appeared.It's the handle that causes it,Landie phenomenon! Puma 110 SW
90 V8 SOFT TOP
Post #38743 21st Aug 2010 1:59pm
mse
probably ever thinner metal Exclamation Mike
Post #38758 21st Aug 2010 6:03pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Ive straightened mine by taking the trim off the inside and glueing some plywood (dont laugh it's only tempoary) so it pushes the dents out. I found that the door handles were not the cause of the dents as I slakened mine off and they were still there. The passanger door is now perfect but the drivers door is still a mess, I am going to take the door off and place it on a flat surface so I can puch them out properly. 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #38763 21st Aug 2010 7:08pm
dgardel
Italy
All cars have CURVED surfaces.
Defender has PLANE surfaces so, You can build the Defender doors with 3mm Birmabright or steel, but when you close a screw or a rivet/nut you'll note a bend surface Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #38778 21st Aug 2010 10:19pm
dgardel
Italy
Unpainted defender:
[img]http://www.landrover.com/imagery/global/nameplate/photos_and_video/wallpapers/defender/All_Explore_Wallpaper_L316_INT_Shell-850x425[/img] Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #38808 22nd Aug 2010 9:13am
Grockle
as often said it's a Defender and as such................ 2.4 90 XS
Post #38811 22nd Aug 2010 9:14am
mse
dgardel wrote:
Unpainted defender:
Thats still knoking around
The thinner the metal they use (and it has got that way) the worse it has become...probably not helped by steel doors that once werent! Mike
Post #38839 22nd Aug 2010 1:56pm
