![]() | Home > Maintenance & Modifications > Exposed Cabling |
cant be high level brake light or window heater as they run into side of door half way up
could be for worklight if fitted , but what ever it is , yes should go behind the rear quarter light trim |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
its probably the hose that carries the water for the rear washer. just tuck it behind the trim yeah.
be careful not to break it, i damaged it on my old 90 and next time i used the rear was wipe it all squirted over the dogs in the back ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 ![]() ![]() |
Hhhhmmm, No rear work light fitted or been fitted (as far as I can tell).
Will go and have a closer look in a bit. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Yes, It's the black plastic hose for rear washer [mine is the same] along with a black cable on mine, terminating who knows where?
HT's don't have window trim, so it just runs up the side of the door frame ... worry not ![]() |
What's it held on with as ours has obviously come away? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Self adhesive pads .. mine came away a long time ago ... just run a line of adhesive sealant along it and stick it in place with tape until it dries
