Home > Maintenance & Modifications > Exposed Cabling
CatherineF
Exposed Cabling
Bare with me on this guys.
At the rear of our 90 HT as I look at it out of the window I can see a cable through the drivers side rear quarter light. I suspect this should be buried behind a trim panel.
It s a cable that runs vertically I would guess from the right hand side lights up to i would guess the heater rear screen/brake light.
It has been exposed (by this I mean not hidden behind a panel) since we picked her up and we've not done anything with it really until the rear screen was sorted.
Can anyone tell me where it should go? Is it easy to just push it back behind the trim panel? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #387367 11th Jan 2015 12:19pm
munch90
cant be high level brake light or window heater as they run into side of door half way up
could be for worklight if fitted , but what ever it is , yes should go behind the rear quarter light trim
Post #387377 11th Jan 2015 12:42pm
Cheshire110
its probably the hose that carries the water for the rear washer. just tuck it behind the trim yeah.
be careful not to break it, i damaged it on my old 90 and next time i used the rear was wipe it all squirted over the dogs in the back Rolling with laughter Cheers, David
Post #387380 11th Jan 2015 12:44pm
CatherineF
Hhhhmmm, No rear work light fitted or been fitted (as far as I can tell).
Will go and have a closer look in a bit. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #387381 11th Jan 2015 12:49pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Yes, It's the black plastic hose for rear washer [mine is the same] along with a black cable on mine, terminating who knows where?
HT's don't have window trim, so it just runs up the side of the door frame ... worry not Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #387414 11th Jan 2015 2:45pm
CatherineF
What's it held on with as ours has obviously come away? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #387415 11th Jan 2015 2:47pm
Dave-H
Self adhesive pads .. mine came away a long time ago ... just run a line of adhesive sealant along it and stick it in place with tape until it dries Cool Guns and Landrovers .... anything else is irrelevant.
Post #387420 11th Jan 2015 2:59pm
