![]() | Home > Puma (Tdci) > PUMA MY2014 junction box battery relay identification |
| LesDef Member Since: 06 Aug 2012 Location: Western Australia Posts: 9 |
Hi TonoDef,
Please see below a list of relays numbered as per your photo:- 1 = R100 Main 2 = R104 Power 3 = R117 Cooling Fan 4 = R123 Headlamp 5 = R138 Heated Rear Screen 6 = R134 Front Wipers 7 = R103 Fuel Pump 8 = R102 Starter 9 = R176 Blower 10= R181 A/C Comp. Clutch Hope this helps. Regards LesDef |
| zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669
So the headlamps are relayed now? No need for a swedish cable loom? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18045
There has always been a relay in the circuit for Defender headlights - it is energised by "ignition on" and ensures that the headlights only come on with the ignition. It doesn't alter the fact that the full headlight current passes through both the light switch and the high/low beam (dip) switch.
The high-current contacts of the relay are in series with the two manual switches. |
| TonoDef Member Since: 23 Jul 2014 Location: LILLE Posts: 14
It does, thanks LesDef, really appreciate it.
Did you got the solution by looking at the wires or Have I missed a document somewhere ? Thanks again |
ok, thx |
Hi TonoDef,
I have moved the under drivers seat (RHD) electrics to a box inside the cabin under the centre consule. During the proccess I noted the wire colours to each of the relays and checked them against the wiring diagram. I have not found any documents to designate these relays. Simple for an Electrical Draftsman. Regards LesDef |
That's what I call a real job ! You go diving with yours ?
Have a good one Les ! |
| nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
i know tihis is an old post but do you have any pictures of your work? |
Gidday nitram17,
No photos of my work, at the time I was in a hurry preparing to for a trip across the Simpson Desert. You can check out the Ex-box at http://www.expeditioncentre.com.au/exbox~4516 Don't know if your at Newcastle pommieland or NSW which will effect viability. Regards LesDe |
| Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339
Not completely true since 2012 model year. Whilst the dip switch does carry the full lighting current (and is still the weak link), the headlamp switch now operates the relay in the junction box. The relay that enables the headlights with the ignition on is by the main fuse box (bottom row, right hand side) |
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802
Fifth Horseman,...does that mean that the headlight switch in post 2012 Defenders is not so "vulnerable"?
Pickles. |
Yes, the main switch now only carries the current for the sidelight circuits and activates the additional headlamp relay. There was a tech bulletin to bypass the main switch with a relay on earlier vehicles. https://www.defender2.net/gallery/albums/u...0relay.pdf
Shame L/R didn't use relays to bypass the dip switch, but then that would give us nothing to modify.... |
| Maverick90 Member Since: 07 Jan 2017 Location: South Yorkshire Posts: 12
Is one of the relays shown the glow plug relay and does anyone have a part number for them?
Interesting thanks. I didn't know about that TSB. A very complex way to do half a decent job! |
| All times are GMT |
