![]() | Home > Maintenance & Modifications > LED headlights |
| SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733
Cant argue with that logic although I wasn't referring to trucklites, it was only meant as light hearted response to Land rover thinking Noldens are better in the post above.
Im sure they all have hidden agenda's in reality as to why certain companies are chosen before others, but maybe I'm just cynical |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Or bombarded with JW Speakers every time you dare mention noldens
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Bombarding? Who's bombarding here? Apples and pears keep flying in our face incessantly,
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
At the risk of being accused of bombarding people, how does one actually compare different items without using performance figures? When it comes to appearance of different items that is down to personal choice/opinion.
There is nothing odd or apple and pears about the figures I have quoted. That data is taken from the manufacturers website and to the best of my knowledge is accurate. If I have made a mistake in those figures, that I have taken from the manufacturers website please tell me. IF I make factual errors in anything please tell me and I will correct it. Last night drove home in vehicle with Noldens in, night before it was standard LR candles, tonight it should be in a vehicle with JWS 8700 in. I know which one I prefer come nighttime driving, however that is my personal opinion. Brendan |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Quoting an organisation that wastes 10s, if not 100s, of millions of dollars on weird and wonderful vehicle procurement exercises every year doesn't exactly reassure me on anything I'd want fittted to my Defender.
I think tastes there can change very quickly. Warn used to to have an almost exclusive contract for winches for the Humvee fleet, then someone decided Milemarker were better and they were all swapped out. i think Warn now have their foot in the door again... Do the headlamp manufacturers actually quote the make and model of the LEDs they use? I know from my recent research on torches there's been significant development and improvement between each generation of LED and even in the iterations as time goes on. |
| nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546
And JLR decided to use NOLDEN headlights on the Defenders! WANTED:
SII or SIII in max 1.5k |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Oh the irony......Is that supposed to justify something on an agricultural vehicle that has switchgear from an Austin Meastro, leaks like a sieve and certain items rot out within weeks of leaving the dealership? If so that's funny..... Aside from that irrespective of output etc....The IP rating to me is of paramount importance with my experience. You can have a light with the highest lumen/candellas/Swan Vesta (or whatever you want to call it) output in the World. Fill the lens with condensation how good is that output and beam pattern then? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Bought a set of the Noldens from Brendan... Great service and an excellent product... Light pattern is excellent and if there set correctly there are no dim spots.... There so good I've spoken to Brendan about supplying another set for my Bowler Defender when it goes to build..
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
o Remember this which comes out of dedicated thread to the topic?
Well, while I fully accept the relevance of IP67 and IP69, which are according to one and the same standard, I have seen nobody on here been able to proof that Nolden and Speaker use one and the same recognised international standard when they talk about measured, respectively effective, lumen. Without such a clearly defined standard as common denominator it just is not correct to compare those numbers at all and to use them to try to show that one is better than the other. The numbers are so different, and our eyeball test which is not as faulty as someone here pretended clearly showed that the light output of both are comparable. For now, the only numbers which can be compared with confidence is those provided by Speaker for the EVO and for the EVO2, we can assume that one manufacturer will use the same testing standard for his lights, yes? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| mpm Member Since: 28 Mar 2013 Location: Cheshire Posts: 8
Does the rubber boot which reduces water ingress to the connection on OEM lights fit any of the led lights, if not does anyone supply a boot that does keep the connection dry
NO you can NOT make that assumption! Noldens have always quoted a raw lumen output and a measured lumen output JWSpeaker have quoted a raw lumen output and an effective lumen output. From JW Speaker website
Now JW Speaker used to CALCULATE the effective lumen output. Eric, you used to complain that I was comparing the 8700 CALCULATED lumen output with the Nolden MEASURED light output. Now I quote JW Speaker website again
So NO you can NOT assume that JW Speaker figures has been done the same way. On JW Speaker 8700 they CALCULATED effective lumen but for the JW Speaker 8700 EVO2 it is a MEASURED lumen output. That is your apple and pears argument within the same company. So JW Speaker 8700 Evo 2 MEASURED light output by a photometric testing device is 1150 lumens Noldens 7" Bi Led MEASURED light output is 1700 lumens Now I am prepared to accept both manufacturers measured light output figures. Like wise I am prepared to accept their respective IP ratings, current draw, physical measurements etc. On none of those measurements do either manufacturer state what particular test standards they have used. Brendan |
Yes the OEM boot does fit! Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Whatever you say Brendan, but in nothing of this I see any common denominator which would justify that anybody can quote numbers to pretend that one is throwing out more light than the other. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
IP67 Immersion up to 1 m Ingress of water in harmful quantity shall not be possible when the enclosure is immersed in water under defined conditions of pressure and time (up to 1 m of submersion). Test duration: 30 minutes The lowest point of enclosures with a height less than 850 mm is located 1000 mm below the surface of the water, the highest point of enclosures with a height equal to or greater than 850 mm is located 150 mm below the surface of the water IP6K9K German standard DIN 40050-9 extends the IEC 60529 rating system described above with an IP69K rating for high-pressure, high-temperature wash-down applications.[7] Such enclosures must not only be dust-tight (IP6X), but it must also be able to withstand high-pressure and steam cleaning. The test specifies a spray nozzle that is fed with 80 °C water at 8–10 MPa (80–100 bar) and a flow rate of 14–16 L/min. The nozzle is held 10–15 cm from the tested device at angles of 0°, 30°, 60° and 90° for 30 seconds each. The test device sits on a turntable that rotates once every 12 seconds (5 rpm). The IP69K test specification was initially developed for road vehicles, especially those that need regular intensive cleaning (dump trucks, cement mixers, etc.), but it also finds use in other areas (for example, the food industry and car wash centers). To date I have not heard of one case of condensation in Nolden lights Trucklites also have an IP rating IP69K The lights mentioned by the OP are quoted as waterproof but without an IP rating. So to best of my knowledge the only LED headlights available in the UK with the highest water proof ratings of 9K are Truck Lites and Noldens Brendan Edited to add Eric, Lazer Lamps, a respected UK manufacturer of LED light bars does not quote a standard for their light output Light Force, a respected Australian manufacturer of lights including LEDs quotes raw lumens and does not quote any standard used for measuring light output. So basically you do not accept the light figures from several of the worlds major light manufacturer Last edited by leeds on 18th Dec 2014 12:34am. Edited 2 times in total |
