![]() | Home > Maintenance & Modifications > LED headlights |
mpm Member Since: 28 Mar 2013 Location: Cheshire Posts: 8 ![]() ![]() ![]() |
K9f,
Thank u excellent pic. Are those Noldens ![]() |
Mpm, that may be the case with cheaper LED's manufacturers.
Nolden headlights are tested to The test specifies a spray nozzle that is fed with 80 °C water at 8–10 MPa (80–100 bar) and a flow rate of 14–16 L/min. The nozzle is held 10–15 cm from the tested device at angles of 0°, 30°, 60° and 90° for 30 seconds each. The test device sits on a turntable that rotates once every 12 seconds (5 rpm). Or 80 C water, minimum pressure of 1160 psi from a maximum distance of 6" is a pretty demanding test I would say To date I have not heard of one failure of Nolden lights. We supply a lot of Nolden DRL's as well as 7" headlights and have not had to replace one unit yet for any reason! Brendan Last edited by leeds on 18th Dec 2014 12:43am. Edited 1 time in total |
Welcome! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
They are also subjected to a 480 hour salt spray test. Working as a design engineer whos parts are used by many of the major car companies, I know this can be a tough test on any metal parts. I'm not sure of the exact detail of their test, but typically the parts are sprayed with a salt spray for a number of minutes, baked for an hour and the cycle is repeated for 480 hours. http://defender90xs.blogspot.co.uk/ |
Looking at some customer specs, the Japanese OEMs consider 96 hours to be 2x life testing i.e. 20 years.
The harshest spec I've seen in 960 hours which is made up of 40 cycles of: 6 hours spraying 5% salt solution at 30 degrees 1 hour at 60 degrees to dry it 16 hours at 50 degrees and 95% relative humidity Finally 1 hour ramping back down to 30 degrees to repeat. http://defender90xs.blogspot.co.uk/ |
