|  | Home > Technical > 3rd Brake Light Issue and...... |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Catherine this is a very common occurence in earlier Pumas. By removing the shroud that covers the rear brake light you will see where it will have worn through the element. I'll update this with a few links. Latter models have an element that routes around the brake light. You may be able to fix it with Granville (not the Open All Hours variety) available from Halfords or any decent automotive bits 'n' bobs supplier.
 **EDIT** Linky fingys added... Granville: http://www.halfords.com/motoring/garage-eq...ter-repair Issue in more detail: http://www.defender2.net/forum/topic8507.h...ow+element http://www.defender2.net/forum/topic16715....ow+element http://www.defender2.net/forum/topic2260.h...ar+element  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 16th Dec 2014 8:52am. Edited 1 time in total | ||
|  16th Dec 2014 8:43am |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067    | And look here:
 http://www.defender2.net/forum/topic14968.html | ||
|  16th Dec 2014 8:51am |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Ahhhh,
 I think this is going to have to be referred back to the dealer as the car has had privacy film applied, although I'm guessing that has just gone around the rear brake light housing. Last edited by CatherineF on 16th Dec 2014 9:03am. Edited 1 time in total | ||
|  16th Dec 2014 8:56am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | This is the latter newer glass that has the element rerouted.
   Click image to enlarge I too had a window tint and as a result couldn't get mine swapped out under warranty for the same issue. Also it may be that the tint was fitted after the issue was already there in which case the tint may need to come off. The window above was from a For Sale thread. If you need one they can be got from anyone that has or is going to have Landyglass/VSG or whatever it is called this week. May be worth giving David or Claire a ring if you need one? I subsequently replaced all my rear windows eventually so got rid of the issue. Good luck.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  16th Dec 2014 9:00am |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Is it likely that the brake light is suffering from the same issue? | ||
|  16th Dec 2014 9:15am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Yes 'shared earth'.... first link after 'Granville' look at Dgardel's photo in the associated thread, it will become clear. (The problem not the window.)     If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  16th Dec 2014 9:24am |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Doh!
 Missed that bit! Thank you. Fingers crossed we can get it all sorted without new glass and film. | ||
|  16th Dec 2014 9:46am |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Took it down to The Pike Associates in Trowbridge and they have ordered a repair kit.  Decided as it was under warranty to take it to someone who should know what they are doing.
 So fingers crossed by the end of the week it will be working. | ||
|  16th Dec 2014 3:13pm |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    |
   Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  16th Dec 2014 9:54pm |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Frustrated to say the least.  It went in this morning to a local specialist.
 He's confused and needs is back in early January to chase down the issue. Supposedly there was power and when it was tested a 2nd time there was no power to a connector top right. The only thing he has noticed is a little mark on the black surround of the brake light (see photo). Of course sods law it's Christmas and they will be closed so it can't be looked at until 5th January. Does anyone know of a good Auto Electrician in Wiltshire?   Click image to enlarge | ||
|  23rd Dec 2014 11:37am |
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831      | If you want to make a temporary repair and are close to a motor factors you can buy a tube of paint on repair solution that will fill in a small nicks in the filament.  something like this http://www.amazon.co.uk/heated-rear-window...pair%20kit or herehttp://www.halfords.com/motoring/garag...ter-repair Don't make old people mad.
 We don't like being old in the first place, so it doesn't take much to  us off. Richard | ||
|  23rd Dec 2014 1:20pm |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Well that's what the specialist had supposedly ordered in.
 I'm not impressed as you can gather because it was booked in for an hour. I wasn't there this morning but as I understand it, it now needs to go back in to be chased back. I've got another specialist who also said bring it in on the 29th and we will have a look and maybe get someone in. So I'm thinking I'd probably just be better with someone electrical. | ||
|  23rd Dec 2014 2:46pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | My brake light track (also early Defender) has failed near the connector down in the bottom right of the window.
 To fix, I've run a cable up the side of the window seal to the light fitting (which bypasses the track) until I get around to fitting a new window. The cable is neatly out of sight. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  23rd Dec 2014 3:17pm |
| Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98      | If you speak to Dave at VGS ( formerly landyglass ) he will supply you with a tinted heated screen with  LED , high level light for a very reasonable price.
 Never been a fan of stick on tints for these potential related issues.  | ||
|  23rd Dec 2014 3:36pm |
| Posting Rules
