|  | Home > Technical > High level brake light earthing question... |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067    | The brake light has probably rubbed through the glass element.
 This seems quite common. Does your heated rear window still work?... as the top few elements on the glass also often get damaged as well.   I ran a wire up from the connector to the lamp holder and tucked the wire behind the rubber glass seal to hide it. Get it sorted under warranty but it will probably do it again in time....you could cut the foam seal where it comes in contact with the glass so no rubbing takes place. | ||
|  12th Sep 2012 8:05am |
| AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128      | Hi,
 in my case they first did not find the cause, after I took a few minutes to find it, they replaced the entire window in warranty. The cost for replacing the dark foil they did not take. BR Oskar | ||
|  12th Sep 2012 8:09am |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517      | ^^^
 cheers for the replies guys. rear window element does look well rusty/tarnished for a 2 yrs old motor. shonky LR design  | ||
|  12th Sep 2012 8:54am |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935      | The original Heated rear window has horizontal elements at the top that are covered by the high level brake light assembly. Vibration of this unit causes a break in the heating element. The NEW replacement heated screen has the top 3 elements running AROUND the High level brake light unit thus sorting the problem permanently .   LANDYWATCH   Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php | ||
|  12th Sep 2012 9:26am |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | When the brake light packed up on mine earlier this year it was because the spade connection close to the bottom of the window had been knocked off. This was the earth from the brake light, from the bulb carrier the earth went to one of the studs which passed through a printed strip on the glass which is independant of the heating element and is there to complete the circuit. All I did, as done above, was run a wire from the stud, conceal it behind the rubber window seal and earth it behind the door card.
 All this has been tidied up due to some kids using the back window as target practice with a football so back to originality! | ||
|  12th Sep 2012 10:18am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Is your right hand rear brake light working? The high stop tail light shares it's earth with the right hand lower. Could be where the two are spliced the splice has broken or the common earth is duff. Yes it does share the earth with the rear heated window 'C0557-1' on the diagrams.
 Run in an alternative earth like the temporary one you tried, or buy a Granville Electrical Circuit Paint Repair Kit and get painting would be my advice. Save yourself a packet. http://www.google.co.uk/products/catalog?h...CB4Q8wIwAA If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  12th Sep 2012 11:07am |
 Welsh Gas   just been to the dealer armed with 'knowledgable' details about new and older rear windows, and having looked at mine ('10) and a new truck in the showroom, he has ordered a new window   cheers al | ||
|  12th Sep 2012 12:39pm |
| defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411      | Wow, that's handy stuff to know about, thanks.    | ||
|  12th Sep 2012 12:41pm |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935      | You're welcome. Glad to be able to help out.   LANDYWATCH   Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php | ||
|  12th Sep 2012 1:13pm |
| ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517      | Cheers WelshGas,
 On the above info passed, I ran this past the stealer and they have fitted a new version screen today. I had to wait for a new bumper to arrive, as I mentioned the light corrosion inside the web. The dealer (not my purchase dealer) seemed not to put up a fight... Q: are they 'making' on this work as such, from LR. Stratstone, Newport Pagnell...seem  | ||
|  16th Nov 2012 9:06pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
