|  | Home > Technical > Squeaky Clutch |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      | Quite common yes. Could be the spring that sits just above the pedal pad so try lubricating that first especially where it works on the pedal shaft, to lubricate the pedal pivot properly means removing the pedal box cover under the bonnet - ok you can do it from below [inside the vehicle] but it's a bit hit and miss. Steve.
 Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. | ||
|  12th Dec 2014 6:28pm |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Thank you!  Are we talking WD40 or some other lubricant   | ||
|  12th Dec 2014 6:29pm |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006    | Call me odd or superstitious, but every land rover I have ever had with a squeaky clutch pedal has been a cracker so I'm very reluctant to do anything to rectify it     No doubt a squirt of maintenance spray on the pedal pivot would sort it out if you wanted to  | ||
|  12th Dec 2014 6:30pm |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Haha, funnily enough I've got the feeling that this is going to be a very good vehicle. | ||
|  12th Dec 2014 6:34pm |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006    | Best keep the squeak then ha ha !    | ||
|  12th Dec 2014 6:36pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042    | WD 40 might be a bit light and dissapear fairly quickly, any problem with using a small amount of grease instead such as lithium or moly? | ||
|  12th Dec 2014 6:40pm |
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087    | I think I would use ACF50 in such cases, with the added benefit of a fine tube for precise location...  Rog...   The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] | ||
|  12th Dec 2014 6:43pm |
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 570      | If you open the bonnet and look at the side of the pedal box where the pin where the clutch pedal pivots, there's a 6mm or 1/4'' thread (I can't remember) I put a grease nipple in there and it solved my squeaky pedal.
 Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop | ||
|  12th Dec 2014 8:22pm |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      | ^^Yep, did that with my last Puma which had a persistent pedal squeak. Steve.
|  12th Dec 2014 8:29pm |
 Any decent lubricating oil or light grease will do. Steve. Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. | ||
|  12th Dec 2014 8:31pm |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      | http://www.defender2.net/forum/topic32878.html Steve.
|  12th Dec 2014 8:36pm |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971      | Are you sure a mouse hasn't moved in?    WD40 is a pretty pants lubricant and can make things worse by washing the actual lubricant off. 3-in-1 would be better but there are loads of products out there. We use quite a lot of this stuff for a general squirty oily stuff in a can that doesn't cost too much: http://beal.org.uk/lubrication-cleaning/ae..._3093.html It's called "chain and cable lube" but it penetrates well and is pretty sticky so good for a lot of things. | ||
|  12th Dec 2014 11:52pm |
| steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767      | worked on my 90    | ||
|  13th Dec 2014 4:22pm |
| CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762    | Well a part success today.  We put a little bit of 3 in 1 oil on the spring at the top of the pedal arm and it's definitely improved it. So tomorrow we will give it a proper lube and hopefully that will sort it. | ||
|  13th Dec 2014 5:16pm |
| Posting Rules
