Home > Maintenance & Modifications > Squeaky clutch pedal
MarkyMark
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi,
I have an annoyingly squeaky clutch pedal Confused (2010 Puma 2.4). I have tried WD40 with success.
Any suggestions from the wise appreciated.
Mark
Post #373496 22nd Nov 2014 4:29pm
landy andy
The only way go stop the squeak is to apply a hood oil (not WD40) on the pivot of the pedal from above. This needs to be done via the cover, that is held on with six screws, under the bonnet. Thumbs Up Thumbs Up
Tried all other methods Big Cry
Andy
Post #373499 22nd Nov 2014 4:59pm
X4SKP
Hello MarkyMark
I had this issue on my old 300dti and the only fix I could come up with was to make a pair of PTFE bushes
that worked a treat but really shouldn't have been necessary.
My 2.4 occasionally gives off the same squeak (which I couldn't live with long term).
If it comes and stays then I will do the same if it is the same arrangement down there.
Havn't heard of Hood Oil (but will now check it out)
I'm still of the belief that WD40 will fix most things. SKIP
Post #373502 22nd Nov 2014 5:08pm
mark_d
Post #373506 22nd Nov 2014 5:23pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine was the big spring at the bottom going squeak squeak. WD40 dried out after a week; a few drops of 75w90 fully synthetic gearbox oil worked a treat. Its still ok a year on. 1953 80"
1987 mini city e
2011 90"
Post #373511 22nd Nov 2014 5:45pm
MarkyMark
Cheers Guys for the fast replies. I will investigate further !
Post #373513 22nd Nov 2014 5:51pm
ericvv
Post #373514 22nd Nov 2014 5:51pm
Philslandy
Germany 2002 Defender 110 Td5 SW Epsom Green
I had for a time the same Little bird stepping on the clutch on my TD5/110...
On a tour through the Alps it was to much - i had to take out my Toolbox Laughing
I like the idea of the nipple, but how does the grease find it`s way to the outer place of the axle?
It would be necessary to drill some holes in the end of the axle...?
Post #373532 22nd Nov 2014 7:19pm
X4SKP
Well done mark_d and ericvv
There's a fix here to be had I think... the birdies going to get it... Exclamation SKIP
Post #373544 22nd Nov 2014 8:10pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I had the same problem had new bushes fitted Thumbs Up
Post #373558 22nd Nov 2014 8:41pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
My 90 has a plug in the end took it out gave it a spray left it for ten minutes, no squeak. Thankyou for your post. I can now hear the brake pedal squeaking Rolling Eyes
Post #378512 12th Dec 2014 8:15pm
