Home > In Car Electronics > Simple route sound improvement?
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Nothing too bad about my current [Standard] ICE set up ... but looking to improve the sound quality a tad without fitting bigger speakers, sub, etc,etc.. So ....
Are there 10 cm speakers out there that will give a much improved sound quality over the standard fit, But still using the LR radio? Could do with a bit more bass, and a less high tinny'ish sound.
Are there better tweeters to fit top of dash, or is it better to just disconnect those? [They sound worse of all!]
I know Steve loves his Kenwoods, and many others rate Focals Razz ... But just as a 'speaker only' upgrade, which gives the best all round sound? Guns and Landrovers .... anything else is irrelevant.
Post #378391 12th Dec 2014 2:30pm
In my opinion, the best 'simple' upgrade is a powered sub fitted to the rear of the cubby box.
I know it's not as easy as simply changing the existing speakers (and you said without fitting a sub) but 'bang for buck' it'll give you the most improvement
Post #378399 12th Dec 2014 2:54pm
jimbob7
Which LR radio is it?If they still use the one made by Siemens VDO an empty space in the dash will sound better,you can upgrade 4 inch speakers quite easily and cheaply And there's always H.U on sale at Halfords anorl,which are better and more reliable than Siemens Pov.spec,ftw. 2006, 110,TD5.
Post #378402 12th Dec 2014 3:05pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I wanted to do the same without too much faff.
I did however end up with one of these (Kenwood KSC-SW11) mounted on the back of the cubby box (http://www.ebay.co.uk/itm/KENWOOD-KSC-SW11...0779678168)
I also replaced my rear speakers with some Focal PC100s. Still haven't done the fronts as sound now is pretty good. When I get round to it they will be replaced with Focal KRS100s.
It was the sub that made all the difference and I only did the rears as one of them was playing up. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #378411 12th Dec 2014 3:53pm
Martin
Site Admin
Question is, Kenwood or Alpine sub? Kenwood is about £35 cheaper - it's a bit less than your link here: http://www.amazon.co.uk/Kenwood-KSC-SW11-U...B00BO8O9XQ  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #378417 12th Dec 2014 4:21pm
carrotbay
I've got no experience of the Alpine sub. The kenwood one was recommended from another forum user and I've been really impressed with it. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #378419 12th Dec 2014 4:24pm
carrotbay
Here's a link to a Kenwood Sub install .. http://www.defender2.net/forum/topic24922.html 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #378421 12th Dec 2014 4:25pm
Martin
Site Admin
There have been lots of recommendations of the Alpine too, the Kenwood appears to have an inbuilt amp though, so a neater install. Hmmmmm  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #378422 12th Dec 2014 4:25pm
You know which to choose Martin. Whistle
Post #378424 12th Dec 2014 4:27pm
Martin
Site Admin
Buzz off you Razz  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #378425 12th Dec 2014 4:28pm
Oooo and Merry Christmas to you too! Rolling with laughter Rolling with laughter
As others have mentioned a sub even a small active one will give you more improvement over just a speaker change.
The speaker change is a close runner up though, from changing tweeers all you'll get is better high tones and clarity.
Post #378427 12th Dec 2014 4:40pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Pioneer make active sub's too. This one is an interesting new technology.
http://www.carsoundsandsecurity.co.uk/store/ts-wh500a/ http://defender90xs.blogspot.co.uk/
Post #378438 12th Dec 2014 5:32pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
To answer the OP's question, i should think any decent 4" speakers from a quality manufacturer would do the job perfectly. Just a question of budget - buy the best you can afford. Thumbs Up
Post #378445 12th Dec 2014 6:06pm
Dave-H
We definitely are not going sub route .. It's speaker upgrade only... Already got far too many 'additional' wiring looms Whistle
So more recommendations please guys ....... Guns and Landrovers .... anything else is irrelevant.
Post #378527 12th Dec 2014 9:57pm
CatherineF
Got to be honest, the sound from the stereo today when I played it for the 1st time was pants!
Post #378531 12th Dec 2014 10:07pm
