Home > Technical > Prop shaft Survey
Are your pro shaft bolts/nuts tight
I have checked my all prop bolts and they are tight 110
54%
 54%  [6]
I have checked my all prop bolts and they are tight 90
9%
 9%  [1]
I have loose bolts on rear prop 110
9%
 9%  [1]
I have loose bolts on rear prop 90
9%
 9%  [1]
I have loose bolts on front prop 110
0%
 0%  [0]
I have loose bolts on front prop 90
0%
 0%  [0]
I have loose bolts on front and rear props 110
9%
 9%  [1]
I have loose bolts on front and rear props 90
9%
 9%  [1]
Total Votes: 11
AndrewS
Prop shaft Survey
Lets do a little survey to see if we can bottom out the reason for the prop bolts coming loose. I think its got something to do with the low down lumpy torque the Puma engine develops. Thus creating vibrations or oscillation sort of thing. Which at certain frequency's the nuts come un-done Shocked
If you can think of other Q let me know and I will add them.
No Worries Land Rover we will get to the bottom of this and fix it for you Wink
Post #3762 11th Sep 2008 8:08am
TJ101
Andrew,, Idea To keep it spot on, could do with
Whistle
I could then vote that one,, checked a few times after you noted them ages ago Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3763 11th Sep 2008 8:14am
AndrewS
Have you read the options Question Thats the first one Rolling Eyes Rolling with laughter
Post #3769 11th Sep 2008 9:20am
TJ101
Hi, the 110 option was not on my screen, when i posted the above Rolling Eyes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3771 11th Sep 2008 9:41am
AndrewS
Shocked That was the 1st option I placed Shocked
Spooky Thumbs Up
Post #3772 11th Sep 2008 10:03am
mse
You havent got - I havent checked my bolts have no idea if they are loose and now concerned that it is another thing to get round to checking Exclamation Laughing Mike
Post #3780 11th Sep 2008 4:33pm
AndrewS
Rolling with laughter Thumbs Up
Post #3783 11th Sep 2008 4:43pm
discocuzzy
My nuts are fine Andrew...but i have the old model Whistle You cannot teach stupid people to do clever things
Post #3927 17th Sep 2008 11:49pm
AndrewS
Yes we know they are. Whistle
Post #3934 18th Sep 2008 8:15am
DefenderKen
Forgive my mechanical ignorance but could someone tell me where these bolts are?
I reckon I could have this problem so want to check - got car back from dealer saying 'we can find no fault with it at all' so I either imagine the clattering when coming to a halt and it not engaging 4th or they are incompetent. Shocked
Ken Stornoway Grey 90 XS
Focus C-Max Tdci
Kawasaki ZX6R C6f
Post #3946 18th Sep 2008 2:51pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Ken
Hi Ken,
I think you will probably find its incompetent's but for your own checking,
The prop shafts are the shafts coming out of the transfer box, one going forwards into the front diff and the other coming out backwards going into the rear diff. You will recognise them as they look the same etc. These are held on at either end by 4 nuts & bolts and it is these that are coming slack.
Hope thios helps but if not let me know and I can meet up with you.
By the way are you going to the Cheviot 4x4 winch event this Sunday?
Russell.
Post #3950 18th Sep 2008 4:20pm
