![]() | Home > Technical > Prop shaft Survey |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Andrew,,
![]() I have checked my all prop bolts and they are tight 110 ![]() I could then vote that one,, checked a few times after you noted them ages ago ![]() Main Brian James Trailer Dealer for South West UK |
Have you read the options
Hi, the 110 option was not on my screen, when i posted the above
![]() ![]() Spooky ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5107 ![]() ![]() ![]() |
You havent got - I havent checked my bolts have no idea if they are loose and now concerned that it is another thing to get round to checking
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
My nuts are fine Andrew...but i have the old model
Yes we know they are. ![]() |
DefenderKen Member Since: 09 Aug 2008 Location: Northumberland Posts: 15 ![]() ![]() |
Forgive my mechanical ignorance but could someone tell me where these bolts are?
I reckon I could have this problem so want to check - got car back from dealer saying 'we can find no fault with it at all' so I either imagine the clattering when coming to a halt and it not engaging 4th or they are incompetent. ![]() Cheers Ken Stornoway Grey 90 XS Focus C-Max Tdci Kawasaki ZX6R C6f |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 844 ![]() ![]() ![]() |
Hi Ken, I think you will probably find its incompetent's but for your own checking, The prop shafts are the shafts coming out of the transfer box, one going forwards into the front diff and the other coming out backwards going into the rear diff. You will recognise them as they look the same etc. These are held on at either end by 4 nuts & bolts and it is these that are coming slack. Hope thios helps but if not let me know and I can meet up with you. By the way are you going to the Cheviot 4x4 winch event this Sunday? Russell. |
