| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
Took son to be picked up at lyme services M6 then drove back home rather than him leaving the 90 at lyme services all day then ordered a new steering shaft and ball joints as it feels like driving a series on the motorway and everything else has just been done
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018
Got the 110 back after a new gearbox, clutch and disco transfer case. Now I need to put back in the interior carpets and cubby box 1999 Defender TD5 110
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Another job done before the MoT in a couple of weeks. Had a look round the fluid levels a couple of days ago and noticed some play in the UJ's on the steering column, so today a new lower column assembly came in the post and out I went to fit it. It's amazing that when the old one was on the motor there seemed to be no end of play in the upper joint but when I got it off it didn't seem too bad, new one fitted and I'll see how much difference it makes on the school run this afternoon.
On a high note, my Eberspacher is working like a good 'un after I cleaned out the gauze filter on the inlet side of the pulse pump, so much quicker in firing up now and the pump seems a little quieter. |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Took the headlining out and put in some thermal/soundproofing insulation.
Hopefully the last time I take my headlining out as it is such a pain in the butt job to do. Had some (very limited) help from the dog who made it his business that whenever I was cutting the sheet of insulation on the floor it needed sniffing or the side of my face needed licking, or a ball dropped on it so we can go play again. Love him Then made a start on lining out the rear loadspace with the same. Just need to do the bulkhead and doors and we should have a much quieter and warmer (not to mention less condensation) 110 Self confessed mileage hunter |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
Programmed in my new key fob thanks to Gary @ Alive lending me his diagnostics.
Fitted a new RDX steering wheel
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Took the interior rear side panels off the Tdci SW to enable me to put the two nuts, that have been rattling around behind the trims for the last couple of months, back on the side panel retaining bolts.
Couldn't find the loctite so I am sure I will be repeating the process soon Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Replaced the bonnet switch, put the carpets back in and the cubby box.
Did a run to the tip and went to get 2 x 16ft 2" ally poles for a HF long wire setup I am doing - but despite being in stock on the website, non left, so ordered two of them 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087
Did the SMARTWATER thing all over the place...
SMARTWATER PROMO OFFER ... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
| Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52
Click image to enlarge Went a bit over the top with the Christmas lights! |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
| Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 258
Drove home 240 miles after collecting from Chris (Zagato) who's done an excellent job in protecting both chassis and body
Click image to enlarge |
| Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492
Fitted New brush pack to my wiper motor....all good now
Fellrunner - What did he use in the end? Dinitrol and ACF50 amongst some other stuff?
custom90steve - that's right, dinitrol for the chassis and cf50 and other things for the body - he did the full works, following the water ingress manual etc.
