![]() | Home > Maintenance & Modifications > 110 300tdi soundproofing thread |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
have you driven it yet with it all done? hows it feel? My 109 thread
my youtube channel |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233 ![]() ![]() ![]() |
Not driven this one yet but driven a number with the same deadening in, makes a huge difference. i personally think it's one of the best mods, I have also done the underside of the bonnet. Anyone nicking that on their own is in for a shock it weighs a hell of a lot more now. Just gives the car a quality feel and not like a tin can. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
![]() Click image to enlarge wickes foil back bubble wrap work well. |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Just having a re-read through this thread and I spotted this comment
Might be worth investigating? Also, as an update on my 200Tdi I fitted some Tdci foot well sound deadening/matting things- this has made a huge difference in noise level and I'm fairly certain they should require much less "adjustment" to fit to your 300tdi than they did to my 200 ![]() Self confessed mileage hunter ![]() |
^^ shaggy, I've already changed mid and rear section, suppose i could do downpipes too! My 109 thread
right had bit of spare time today so added a little more sound deadening.
a 20 pack of silent coat done 2/3rds of the roof. think i probably need another 40 sheets to finish whole car! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge My 109 thread my youtube channel |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
I did that to my 90 and it made little difference found lead flashing tape made more difference. I'm 110CSW I find all the noise is from badly fitting panels with lose / missing bolts and the doors. Had a horrendous rattling noise. Turned out the rear roof ladder bottom mount ri. Nuts are lose and rattling!!!! Packed it out with some rubber grommets. Noise gone YAY!! Next to do is strip down drivers door as that's noisy as fook
well that is the roof completed, also did back door! slowly getting there. just 4 doors, bonnet and 2nd row floor to do now!
Top work
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
nope!
![]() ![]() my youtube channel |
OK so today i pressed on with roof and got my 3M thinsulate installed!, fairly easy to work with, used spray glue to stick it up. the thinsulate is mega light so doesn't need much glue!
results, doing roof has been biggest improvement for me! the thinsulate appears to be doing a good job!not had a proper run but it is definitely quieter now! I'm very exited now! as once the liner goes back in it may be little better! also got plenty of other places to put the thinsulate. all 5 doors!!and behind all trim panels. ![]() Click image to enlarge My 109 thread my youtube channel |
Also filled some big voids behind dash, and under my mud consule
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876 ![]() ![]() ![]() |
g-mack,
Loving the effort going into this. Where did you get the thinsulate from and is there a choice of thicknesses? Cheers Rosco 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
got it direct!
http://www.3mdirect.co.uk/automotive-marine/sound-insulation.html i bought 7 sheets, but i think its probably to much! roof only took 3!!!!! My 109 thread my youtube channel |
