Home > Maintenance & Modifications > 110 300tdi soundproofing thread
Page 1 of 3 123>
g-mack
OK i know how much we all like a good sound proofing thread! so though i would start my own
95 110 300 tdi.
rattle bangs squeaks noisy engine!!
need to make it a bit it more user friendly.
the bulkhead has foam matting and the seat box also has same foam matting, thats it!! so plan is
stage 1 deadening, using silent coat deadener.
stage 2 CSF bonded to Mass loaded vinyl this is the noise blocker!!
stage 3 sound absorption ( not sure what i will use yet).
This is gonna be done over next few month so nothing instant here!
so far ive purchased 1 bulk pack of silent coat 2mm sound deadener mat 40 sheets £87
4 sheets of MLV £60
so today i stripped front section of cabin
gone for 98% coverage, making sure i did not cover any screws or nuts & bolts in case i ever have to take apart!.
took best part of the day to strip, fit and re install.
verdict
no major difference!!! Sad
will be adding more tomorrow! My 109 thread
my youtube channel
Post #355003 1st Sep 2014 8:56pm
shaggydog
I'm just going to park up here and keep an eye/compare notes.
Quote:
verdict
Really? That's interesting to find out I had heard good things about Silent coat.
I am also thinking about doing a good sound proofing session on mine but materials are difficult to compare.
I have heard good things about dynamatt but jury seems to be out weather to carpet everything in it or just strategically placed bits.
Post #355005 1st Sep 2014 9:09pm
g-mack
i only went out for a 10 min run but there wasnt much difference. but im sure there was SOME difference!! it is only first Quarter done though! im sure once the 2nd row, boot, utiltiy sides, and roof are done there will be a better improvement. also got doors to do at some stage too!.
the biggest change should be when i add MLV and CCF !! My 109 thread
my youtube channel
Post #355012 1st Sep 2014 9:29pm
JWL
The biggest difference to my Td5 Station Wagon was when I put some neoprene foam matting in the 2nd row seat area. I find it quite amusing when I look inside friends' 110's especially the County models with that funny stuff called carpet! Mine is a bog standard bottom of the range one but the front of mine has the foam soundproofing from the factory with the rubber matting on top. All the seat box on mine is covered with foam and matting where the County models have bare seatboxes under the seats! The amount of road noise that was deadened when I covered the 2nd row are was unbelievable, that plus the load area on mine being ply lined and full of junk makes mine quite bearable Thumbs Up
Post #355017 1st Sep 2014 9:52pm
mk1collector
Silent coat/dynamat etc does not stop noise! It stops rattles and vibration. This is why you only really need to put it in the centre of panels, but I did the whole floor of the defender and will be doing the roof when I have time because I like to do things belt and braces. The closed cell foam and mass loaded vinyl should make the most difference.
Post #355024 1st Sep 2014 10:11pm
g-mack
yea i had fully expected to not use SC at 100% but the bare panels on a defender are so poor it kind of needs it!! in fact i added extra 50% to the 2 floor panels !! Shocked My 109 thread
my youtube channel
Post #355031 1st Sep 2014 10:48pm
g-mack
made a little un scientific vid of some products. it doesn't really tell you much but some might find it interesting
 My 109 thread
my youtube channel
Post #355032 1st Sep 2014 10:49pm
Marky Boy
I did mine with silent coat (TD5 CSW) and found putting two layers of SC so 4 mm round the tunnel and bulkhead made quite a difference. As has been said, the flat panels need to be stopped drumming and then the sound absorbing stuff added.n
Post #355053 2nd Sep 2014 6:54am
g-mack
yea think i might be putting another 2mm in strategic places. even with 100 % coverage the some panels still aren't effectively dampened! My 109 thread
my youtube channel
Post #355143 2nd Sep 2014 12:57pm
GUM97
It's a 300 Tdi, it's supposed to be loud Twisted Evil Twisted Evil Whistle An engine to TDi for!
Post #355228 2nd Sep 2014 8:31pm
Tiger
I found most of the noise came through my (plastic, TD5) Gearbox cover.
The noise went down drastically after I covered it in closed cell foam, MLV and carpet. Thumbs Up
Post #355300 3rd Sep 2014 9:41am
g-mack
used up last bits of bulk kit today. guessing i will probably need another 2 packs to finish it!.
this is all the junk that travels in my boot Rolling with laughter
 My 109 thread
my youtube channel
Post #357039 10th Sep 2014 3:30pm
g-mack
Bought another pack of silent coat, 20 sheets, £44.
got side panel done with extra 2 sheets on to make it 4 mm in places as its a very resonatey (is that even a word?)panel.
nice thud to it now!
also got majority of floor done and finished off the nearside wheel box.
 My 109 thread
my youtube channel
Post #374859 28th Nov 2014 4:52pm
newhue
Australia
g-mack wrote:
SNIP it doesn't really tell you much but some might find it interesting
Laughing you seem to be doing a bit of that......but I do love a good sound proofing tread.
seriously I think you'll get there perhaps dropping it 5db overall after you have spent hundreds on trying. Had a mate who bought some pre moulded 6mm thick rubber seat box, gear box tunnel, and floor mats. Cost him 600 odd quid, results were hardly noticeable. At least he was honest.
But I'm with you brother, I have a dirty ol Tdi here here I'm doing up, and to think it could possibly roll out without some attempt of making it quieter is ridiculous. My Defender and travels
Post #374915 28th Nov 2014 8:31pm
Retroanaconda
Biggest problem with a Tdi is engine noise I find. A 300 is slightly more refined than a 200 but it's still a noisy clattery old thing. The exhaust can resonate as well causing a booming in the back.
My 90 has a layer of FatMat Rattletrap (a dampener like Dynamat) across the whole bulkhead under the dash etc. and the foot wells, floors, transmission tunnel, seat box and rear floor. The upper rear panels have flashing tape because I ran out of FatMat! On top of the aforementioned I have the standard Land Rover CSW footwell/tunnel trim pieces (a dense foam kind of material) and then the standard carpets on top of that. In the back I have just put carpet on top of the base layer. It might benefit from some foam etc. in the back but as I mention above my main bug bear now is engine noise. At higher speeds (60mph) it is still a little loud for my liking - though markedly improved from before. Talking is now possible on the motorway for example, and anyone who's driven one will know that this is not usually the case for the farmer-spec Tdi!
I am considering one of those lead-sandwich engine blankets which drops down the back of the block and blocks the noise from heading towards the cabin.
Post #374919 28th Nov 2014 8:41pm
Page 1 of 3 123>
