![]() | Home > Wheels & Tyres > Winter tyres......Again |
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 ![]() ![]() ![]() |
I recommend these winter tyres (with the snowflake):
245/75R16 Cooper Discoverer S/T Maxx ![]() Wide enough to look good but not so wide as to slither about ![]() Tricky to get a hold of though ![]() Now as for wheels ... Rob |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171 ![]() ![]() |
Don't go for a 245/75R16. There is no point. It just changes your gearing for the worse with no benefit.
235/85R16 all the way. Actually for a good siped winter tyre 7.50R16 would be excellent. For winter use narrower is always better. If you want flotation in snow you need to look at +40" stuff. A narrow tyre gives you more contact pressure with the road and the tyre sticks better. A narrow tyre also cuts through sleet and slush better and gives better directional stability. The proof is in the pudding: ![]() Click image to enlarge |
Just dont get Snow tyres and Winter tyres mixed up
![]() However a while ago on another Martin forum the tyre sage Andy from AJS made a statement that I hold to this day listen to the guys who drive on this white stuff our Nordic friends ![]() ![]() |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 555 ![]() ![]() |
I guess that's part of the problem with a winter and snow tyre in the uk. The needs are different for both tyre and so a compromise is needed. The chance of snow is limited but that's part of the reason for wanting the extra set of wheels incase.
Looks like it's the 235/85/16 option. |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 535 ![]() |
Yes, but why would you want to do that - that euro box looks Shiite ! ![]() |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I have nokian on mine
Not so sure about narrow is better , never seen a snowcat on narrow tyres , always got tracks giving the biggest surface area you can get !
surely the bigger area go got on any slippery better the rally car will be on studs , so another thing altogether , if you got studs not a lot of point worry what width tyres you got |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
A rather nice film and some talking about tyres
![]() I put some Indian made tyres on my p38 245 75 16 if I remember, shocking on warm damp/greasy rounderbouts but impressive in snow. I thought the tc was not working but it was ..... Just needed over 75%throttel to break traction from a 4.6 v8. Stopping was good too ![]() ![]() ![]() ![]() |
I don't know why but I also typed this is not seen? Sorry for double posting
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
That's because Snowcats are designed to 'float' over the snow, instead of to 'cut' through it and find the traction due to the nature of where they operate. Hence why you see the Artic Trucks on massive flotation tyres. In most UK conditions, they would be pointless as we don't have snow deep enough, hence you're better off trying to get through to the tractable surface underneath. Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
Well, if you read my post again I touched upon this as well. Flotation on snow is another thing altogether, and with tyres you need to start going really big, 37-40" and above. Then you can deflate the tyre to get low enough ground pressure to float on top of the snow. But that's not to say that you'd have excellent grip on snowy and/or icy roads. Snowcats are also hardly a good comparison! ![]() Studs don't change the situation. The physics is exactly the same studs or no studs. Contact pressure is the reason why 80% of your braking force is handled by the front wheels. On deceleration weight is transferred to the front, ncreasing traction on the front wheels, which means you can apply more braking force. When you take a narrower tyre you increase your ground pressure which equals more grip. And like I said, with a narrow tyre you can more easily cut through slush to get to the road underneath, giving you better traction and stability. |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Hi Alex, I have driven around Norway / Sweden in the depth of winter on both 235/85/16 and 265/70/16, both sets were Cooper Discoverer M+S tyres, both sets brand new dot codes prior to undertaking the trip, both sets were on the car from the point of leaving the UK so did not have studs in them. The tyre, rather than a size specifically, was recommended to me by guys from the Norwegian Land Rover forum and I have sen others out there using the same tyre. I found no difference between the two. Both had very good grip on the snow, both had good grip on ice and would lock up at about similar level of braking force. Personally, I think the 235s look better as they fill the arch slightly more, but for me that was the only difference between them ![]() |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793 ![]() ![]() |
I just love any tyre, Winter, Snow, Summer or AT and MT.
![]() We have huge stocks of all ![]() www.ajstyres.co.uk 01737 241370 Junction 8 M25 Surrey. |
