Home > Wheels & Tyres > Winter tyres......Again
a13x
Done to death I know, however am looking for a third set of wheels to fit winter tyres to. I've heard all the stories of narrower tyres to get the traction in the soft stuff but has anyone had any back to back testing of varying width.
Specifically I'm looker at the cooper discover winter tyres in 235 or 265 fitment. Hoping to fit them to wolf or blindo wheels
Look forward to the heated debate.
Post #376229 3rd Dec 2014 11:10pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I recommend these winter tyres (with the snowflake):
245/75R16 Cooper Discoverer S/T Maxx Whistle
Wide enough to look good but not so wide as to slither about Razz
Tricky to get a hold of though Laughing
Now as for wheels ...
Rob
Post #376236 3rd Dec 2014 11:23pm
Timo K
Finland
Don't go for a 245/75R16. There is no point. It just changes your gearing for the worse with no benefit.
235/85R16 all the way. Actually for a good siped winter tyre 7.50R16 would be excellent.
For winter use narrower is always better. If you want flotation in snow you need to look at +40" stuff. A narrow tyre gives you more contact pressure with the road and the tyre sticks better. A narrow tyre also cuts through sleet and slush better and gives better directional stability.
The proof is in the pudding:
Post #376267 4th Dec 2014 7:50am
Just dont get Snow tyres and Winter tyres mixed up Rolling with laughter
However a while ago on another Martin forum the tyre sage Andy from AJS made a statement that I hold to this day listen to the guys who drive on this white stuff our Nordic friends Thumbs Up they might just know a thing or two Thumbs Up
Post #376268 4th Dec 2014 8:19am
a13x
I guess that's part of the problem with a winter and snow tyre in the uk. The needs are different for both tyre and so a compromise is needed. The chance of snow is limited but that's part of the reason for wanting the extra set of wheels incase.
Looks like it's the 235/85/16 option.
Post #376291 4th Dec 2014 11:05am
Grouse
Yes, but why would you want to do that - that euro box looks Shiite ! Thumbs Up
Post #376455 4th Dec 2014 9:31pm
mick
I have nokian on mine Thumbs Up
Post #376460 4th Dec 2014 9:40pm
munch90
Not so sure about narrow is better , never seen a snowcat on narrow tyres , always got tracks giving the biggest surface area you can get !
surely the bigger area go got on any slippery better
the rally car will be on studs , so another thing altogether , if you got studs not a lot of point worry what width tyres you got
Post #376475 4th Dec 2014 10:26pm
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
A rather nice film and some talking about tyres Shocked
I put some Indian made tyres on my p38 245 75 16 if I remember, shocking on warm damp/greasy rounderbouts but impressive in snow. I thought the tc was not working but it was ..... Just needed over 75%throttel to break traction from a 4.6 v8. Stopping was good too Razz Razz Range Rover p38 4.6 99 lpg(gone Sad )
Post #376494 4th Dec 2014 11:11pm
Stue5
I don't know why but I also typed this is not seen? Sorry for double posting Embarassed
Post #376497 4th Dec 2014 11:20pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
That's because Snowcats are designed to 'float' over the snow, instead of to 'cut' through it and find the traction due to the nature of where they operate. Hence why you see the Artic Trucks on massive flotation tyres. In most UK conditions, they would be pointless as we don't have snow deep enough, hence you're better off trying to get through to the tractable surface underneath. Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #376514 5th Dec 2014 1:37am
Timo K
Finland
Well, if you read my post again I touched upon this as well. Flotation on snow is another thing altogether, and with tyres you need to start going really big, 37-40" and above. Then you can deflate the tyre to get low enough ground pressure to float on top of the snow. But that's not to say that you'd have excellent grip on snowy and/or icy roads.
Snowcats are also hardly a good comparison! Very Happy If the OP was asking how he could more easily manage to push a snowplow up a hillside then I'd answer that tracks are best, but he's looking for a winter tyre for UK roads. Snowcats have wide shovel like tracks that give superb traction and flotation on soft snow, but how many do you see doing 50mph on motorways and such?
Studs don't change the situation. The physics is exactly the same studs or no studs. Contact pressure is the reason why 80% of your braking force is handled by the front wheels. On deceleration weight is transferred to the front, ncreasing traction on the front wheels, which means you can apply more braking force. When you take a narrower tyre you increase your ground pressure which equals more grip. And like I said, with a narrow tyre you can more easily cut through slush to get to the road underneath, giving you better traction and stability.
Post #376519 5th Dec 2014 8:10am
Stue5
Zeetex was the brand..........
Post #376520 5th Dec 2014 8:18am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Re: Winter tyres......Again
Hi Alex,
I have driven around Norway / Sweden in the depth of winter on both 235/85/16 and 265/70/16, both sets were Cooper Discoverer M+S tyres, both sets brand new dot codes prior to undertaking the trip, both sets were on the car from the point of leaving the UK so did not have studs in them.
The tyre, rather than a size specifically, was recommended to me by guys from the Norwegian Land Rover forum and I have sen others out there using the same tyre.
I found no difference between the two. Both had very good grip on the snow, both had good grip on ice and would lock up at about similar level of braking force.
Personally, I think the 235s look better as they fill the arch slightly more, but for me that was the only difference between them Thumbs Up
Post #376547 5th Dec 2014 10:57am
AJS4X4
I just love any tyre, Winter, Snow, Summer or AT and MT. Wink
We have huge stocks of all Thumbs Up Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #376747 6th Dec 2014 9:47am
