Home > In Car Electronics > Heated seat switch
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
Heated seat switch
Sorry to hi-jack this thread, but i've also spent the weekend fitting Waeco heated seats and now need to wire them in to my 08 Puma. Is there any switch available to replace the small round 2 position switch supplied with the kit, that is more in fitting with the rest of the dash switches? I could use the factory heated seat switch but this only has one position.
This post has been edited by the site administration team: new thread Smile
Post #375772 2nd Dec 2014 12:16pm
Martin
Site Admin
Hi Phil, started a new thread for you as it's about switches rather than wiring.
I'm not aware of any three position (off/on/on) original type switch which could be used.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375775 2nd Dec 2014 12:23pm
Martin
Site Admin
Some info here about using factory switches, but only with one heat setting.
http://www.defender2.net/forum/topic23580.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #375776 2nd Dec 2014 12:28pm
PumaPhil
Thanks Martin, I might try to mount the little round switches supplied into the blanks where the factory seat switches would be. I would like to avoid any extra holes drilled in the dash!
Post #375779 2nd Dec 2014 12:38pm
Tiger
Phil, here's what I did.
I used both Thumbs Up
I used the OE switch to switch the relay on the Weaco kit.
I then left the round switches in the circuit but hid them away. I leave them on P2 as I find P1 a bit pathetic.
I can always change the heat setting if I wanted but find leaving them hidden away and on P2 and switchged form the OE switch just fine Thumbs Up
Post #375785 2nd Dec 2014 1:05pm
PumaPhil
If you say that P1 is a waste of time, then I suppose I could just wire the P2 circuit into a OE switch. Got a few options to think about now...
Post #375800 2nd Dec 2014 2:23pm
