![]() | Home > In Car Electronics > Switched live??? |
These are for RHD but the colours will be the same....Happy Hunting....
![]() http://api.viglink.com/api/click?format=go...Bwdo%253D1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
White with a green stripe is ignition switched and fused 12V.
I assume the kit uses this feed to trigger a relay and not to power the seats? ![]() ![]() |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
Yes it triggers a relay.
Where can I find a white with green stripe? Is it possible to pick up a switched live from the back of the fuse box.ie use one of the spare fuses or pigy back off something thats existing? |
Look at the link I posted....there's loads of switched lives in the diagrams and you can even find your 'green with white stripe' therein (Chapter 501-10 Seating).
![]() Treat every day as if it is your last....one day you will be right!! |
Appreciate that the wiring diagrams can just look like a bunch of lines - may not be totally intuitive
![]() An 07 Puma will have plenty of switched live in the fuse box under the steering wheel ![]() Fuse 33 is the location of the factory heated seat fuse, you might be lucky and pick one up from there. I assume a French spec XS doesn't have heated seats then? ![]() ![]() |
Thanks guys,
I thought fuse 33 might be a good place to start. My truck was origionaly a H/T.but with windows. I am in the process of installing a S/W interieur.Or should I say the parts I like from a S/W. Marc. |
Fuses 34 & 35 are also switched live for the windows if 33 isn't convenient.
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 74 ![]() ![]() ![]() |
Nothing like resurrecting an old thread! This proved to be a fantastic location for me to switch live a relay for my auxilliary fuse box on a 2012 MY 2.2 TDCI.....
