![]() | Home > In Car Electronics > Switched live??? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
These are for RHD but the colours will be the same....Happy Hunting....
http://api.viglink.com/api/click?format=go...Bwdo%253D1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
White with a green stripe is ignition switched and fused 12V.
I assume the kit uses this feed to trigger a relay and not to power the seats? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 583
Yes it triggers a relay.
Where can I find a white with green stripe? Is it possible to pick up a switched live from the back of the fuse box.ie use one of the spare fuses or pigy back off something thats existing? |
Look at the link I posted....there's loads of switched lives in the diagrams and you can even find your 'green with white stripe' therein (Chapter 501-10 Seating).
Appreciate that the wiring diagrams can just look like a bunch of lines - may not be totally intuitive
An 07 Puma will have plenty of switched live in the fuse box under the steering wheel Fuse 33 is the location of the factory heated seat fuse, you might be lucky and pick one up from there. I assume a French spec XS doesn't have heated seats then? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks guys,
I thought fuse 33 might be a good place to start. My truck was origionaly a H/T.but with windows. I am in the process of installing a S/W interieur.Or should I say the parts I like from a S/W. Marc. |
Fuses 34 & 35 are also switched live for the windows if 33 isn't convenient.
