|  | Home > Puma (Tdci) > Adapter shaft upgrade |
| PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 126      |
 Does anyone know if Ashcrofts are coming up with an adapter shaft upgrade on the TDCi.  Pat | ||
|  12th Nov 2014 8:25am |
| PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 126      | Ashcrofts will have an upgrade shaft early next year.  Pat | ||
|  15th Nov 2014 10:51pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | I think as long as there greased then you got a good  chance of them being ok anyway
 I think there strong enough its just the lack of lube much the same as the drive flanges , flanges only seem to wear when there dry same as any normal car really if the splines are dry they wear , props do it , drive shafts do it on front wheel drive stuff, even steering shafts do it | ||
|  16th Nov 2014 8:28am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      |  | ||
|  16th Nov 2014 8:31am |
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242    | The stealers service foreman here was most reluctant to grease it when they replaced the transfer case. I pleaded and he agreed to but who knows if they did.    AlanH. | ||
|  26th Nov 2014 2:21am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | Did he give a reason for not wanting to grease it? | ||
|  26th Nov 2014 9:24am |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      |
 SO they can sell you another one in 12 months time..... | ||
|  26th Nov 2014 11:36am |
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242    | Reason given is that it wasn't a service item......   As an apprentice building gearboxes for road pavers/graders etc I always greased bearings and oiled all shafts and gears etc as a normal part of the assembly process. Maybe LR can't afford a dob of grease. AlanH. | ||
|  26th Nov 2014 10:52pm |
| LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411      | British Airways saved millions a year by removing a single olive from the olive pots... just saying | ||
|  29th Jul 2020 3:14pm |
| Posting Rules
