![]() | Home > Puma (Tdci) > Adapter shaft upgrade |
| PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125
Does anyone know if Ashcrofts are coming up with an adapter shaft upgrade on the TDCi. Pat
Ashcrofts will have an upgrade shaft early next year. Pat
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
I think as long as there greased then you got a good chance of them being ok anyway
I think there strong enough its just the lack of lube much the same as the drive flanges , flanges only seem to wear when there dry same as any normal car really if the splines are dry they wear , props do it , drive shafts do it on front wheel drive stuff, even steering shafts do it |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
| AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242
The stealers service foreman here was most reluctant to grease it when they replaced the transfer case. I pleaded and he agreed to but who knows if they did.
AlanH. |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Did he give a reason for not wanting to grease it?
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205
SO they can sell you another one in 12 months time..... |
Reason given is that it wasn't a service item......
Maybe LR can't afford a dob of grease. AlanH. |
| LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411
British Airways saved millions a year by removing a single olive from the olive pots... just saying
