![]() | Home > Maintenance & Modifications > Squeaky clutch pedal |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
The only way go stop the squeak is to apply a hood oil (not WD40) on the pivot of the pedal from above. This needs to be done via the cover, that is held on with six screws, under the bonnet.
Tried all other methods Andy |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello MarkyMark
I had this issue on my old 300dti and the only fix I could come up with was to make a pair of PTFE bushes that worked a treat but really shouldn't have been necessary. My 2.4 occasionally gives off the same squeak (which I couldn't live with long term). If it comes and stays then I will do the same if it is the same arrangement down there. Havn't heard of Hood Oil (but will now check it out) I'm still of the belief that WD40 will fix most things. SKIP https://www.defender2.net/forum/topic83242.html |
| mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266
Is this of help - worked for me
http://defender90xs.blogspot.co.uk/2013/12...ation.html http://defender90xs.blogspot.co.uk/ |
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270
Mine was the big spring at the bottom going squeak squeak. WD40 dried out after a week; a few drops of 75w90 fully synthetic gearbox oil worked a treat. Its still ok a year on. 1953 80"
1987 mini city e 2011 90" |
| MarkyMark Member Since: 28 Oct 2014 Location: New Forest Hampshire Posts: 62
Cheers Guys for the fast replies. I will investigate further !
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Search reveals the following for Puma 2.4
http://www.defender2.net/forum/post263911.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Philslandy Member Since: 10 Sep 2013 Location: Eifel Posts: 156
I had for a time the same Little bird stepping on the clutch on my TD5/110...
On a tour through the Alps it was to much - i had to take out my Toolbox I like the idea of the nipple, but how does the grease find it`s way to the outer place of the axle? It would be necessary to drill some holes in the end of the axle...? |
Well done mark_d and ericvv
There's a fix here to be had I think... the birdies going to get it... https://www.defender2.net/forum/topic83242.html |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109
I had the same problem had new bushes fitted
| steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767
My 90 has a plug in the end took it out gave it a spray left it for ten minutes, no squeak. Thankyou for your post. I can now hear the brake pedal squeaking
| All times are GMT |
