![]() | Home > Puma (Tdci) > Genuine Land Rover Driving Lamps |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 336 ![]() ![]() ![]() |
If its been fitted as the instructions, the relay and fuse are in the passenger seatbox near the battery. The feed to the switch is from the rear of the instrument panel.
Borrowed from MartinK's gallery https://www.defender2.net/gallery/albums/u...ctions.pdf |
Thanks very much FH
![]() 1968 1/32 scale Britains 109 Pick up. |
Hi,
I have rung my LR dealer who tell me I must buy the whole lamp kit to obtain the relay ! can anyone help with the part number of the relay please. Thanks 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
Have you got a photo or part number from the relay?
As is normal, computer says no at a parts department. The good ones who make the effort are few and far between. It is highly likely to be just a normal 30A or 40A automotive relay ![]() ![]() ![]() |
Thanks Martin,
I'll have a look 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
If you want to do a swap of another one to eliminate the relay as the fault, then you can use the electric window relay. It's a normal relay
Indeed a normal relay, aka YWB500060 @ about £3.80 will do the job.
Not special to LR either, no need for a trip to a dealer.
Any motor factors (even Halfords!) will stock a standard relay ![]() ![]() ![]() |
sorry forgot to ask ,I can't see a fuse in the fitting kit instrictions, where is it ? 2.4 90 XS
On the side of the relay holder.
Thanks Martin and FH for responding so quickly 2.4 90 XS
it was the relay which had corroded inside. 2.4 90 XS
Great, did you swap it for another to test or just buy a new one?
Hi Martin,
Both,swopped it for the Yellow one which is near to it, then fitted a new one YWB500060 £4.60 trade price. Thanks again, Roger (Grockle) 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
