Home > Puma (Tdci) > Washers not wiping.
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Washers not wiping.
I wonder if any of you folks can shed any light on a little problem I have with the washers/wipers on my 2007 Puma.
When I squirt the washers to clean the screen,the wipers no longer do the 3 or 4 wipes automaticaly.I can push the salk up or dow to make the wipers come on,but it should wipe 3 times without doing that.
Where should I start looking?????Stalk,or is there a relay that controls this feature?
Thanks a lot.
Marc.
Post #373051 20th Nov 2014 5:52pm
munch90
isn't there a wiper control unit also does the interrmitant wipe as well , like a big relay in the fuse box , might be wrong sorry cant remember if it controls both
as doesn't it change the number of wipes when you wash when you change to 99 vw one , so think it does both controls ????
Post #373059 20th Nov 2014 6:12pm
K9F
Yes there is labelled as D113 on page 501-16 - WIPERS AND WASHERS of the diagrams available from Dgardel's link here:
http://api.viglink.com/api/click?format=go...7269580318
The '99' one you programme the intermittant period yourself by switching on-off then on again. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373061 20th Nov 2014 6:18pm
sharkey964
Thanks for info guys.
K9
I might be being a bit dim here,but Ican't see.the heading "wipers & washers"so cant find the piece your refering to in the link.
Post #373070 20th Nov 2014 6:35pm
munch90
top middle one in fuse box drivers side under dash (rhd)
Post #373072 20th Nov 2014 6:37pm
K9F
You need to dig about in his site. Not sure if this link will work but if it does it will take you directly to the diagrams.
https://onedrive.live.com/view.aspx?cid=4B...&wdo=1
Once you're into his site look for the 'Workshop Public 2 icon and click.
It will then give you two options dependant on MY year.
Your 'muddy track' doesn't help with location but your flag does (I am in St Malo at the moment) bear in mind the diagrams there are for RHD. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #373075 20th Nov 2014 6:45pm
sharkey964
Very Happy Very Happy Very Happy
Thanks guys.
St Malo is a bit of a treck,8hrs ish.
Im in the Dordogne.
Post #373079 20th Nov 2014 6:56pm
