![]() | Home > Puma (Tdci) > Washers not wiping. |
isn't there a wiper control unit also does the interrmitant wipe as well , like a big relay in the fuse box , might be wrong sorry cant remember if it controls both
as doesn't it change the number of wipes when you wash when you change to 99 vw one , so think it does both controls ???? |
Yes there is labelled as D113 on page 501-16 - WIPERS AND WASHERS of the diagrams available from Dgardel's link here:
http://api.viglink.com/api/click?format=go...7269580318 The '99' one you programme the intermittant period yourself by switching on-off then on again. ![]() Treat every day as if it is your last....one day you will be right!! |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 583 ![]() ![]() ![]() |
Thanks for info guys.
K9 I might be being a bit dim here,but Ican't see.the heading "wipers & washers"so cant find the piece your refering to in the link. |
top middle one in fuse box drivers side under dash (rhd)
You need to dig about in his site. Not sure if this link will work but if it does it will take you directly to the diagrams.
https://onedrive.live.com/view.aspx?cid=4B...&wdo=1 Once you're into his site look for the 'Workshop Public 2 icon and click. It will then give you two options dependant on MY year. Your 'muddy track' doesn't help with location but your flag does (I am in St Malo at the moment) bear in mind the diagrams there are for RHD. ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 20th Nov 2014 7:47pm. Edited 1 time in total |
![]() ![]() ![]() Thanks guys. St Malo is a bit of a treck,8hrs ish. Im in the Dordogne. |
