![]() | Home > In Car Electronics > Electical schema |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Thx
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Why do you need the diodes? If you power the ledbars, the main headlight is isolated by Switch S3 in your schema, no?
Relays are readily available. The headlights in a stock car does not have a relay, power goes via the switch on the stalk to the lights. There are some threads here on modifying that in line with your pic (aside from the second switch S3) Also the switch for the main car headlights won't need the voltage regulator to step down from 12v to 3v Not sure why you have these for the switches for the ledbars - is it because of the 3v led in the switch? |
I need the diodes because if otherwise when I turn on S1 of S2 my high beam goes on as well.
I need to drop down to 3V because of the leds in the switches, yes. I understand that 1A is enough to secure the swichable sectoins, instead of 5A? |
sorry why use switches with 3v leds , you must be able to get a suitable switch for 12v with 12v led , just seems to be over complicating things
may be a typing error , but you have them at 3v/3a , surely a 3v led is not going to draw 3a that's 36w ! |
Won't go on unless S3 is also switched on |
I'm with Munch on this.....Horrendously overcomplicated. With your admittance of limited electrical installation my advice would be get 12v LEDs or an OEM driving light switch, bin the initial concept of being able to switch 2 + 2 (cannot see the point of this as you cannot have too much light) a single switch would be much easier. Switch the relay earth and not the positive it is better as there should be no current in the earth return. Relays draw only mA so a 5 amp fuse is way too big.
Start with a basic installation such as the one below, get that working first then develop and add features like individual switching afterwards, if it doesn't work you'll know exactly where you went wrong. I used two relays to allow for future expansion of the system and when running in the multi-core cables I ensured there were more cores than were needed as this also allows for redundancy and future addition to the system. Not cheap as the price went up a few years ago but a foglight switch is ideal if you have a blank in your dash. http://www.dingocroft.co.uk/cgi-bin/ss0000...s&PN=1 ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
I've used a 1A fuse in an inline holder for mA draw supplies inside with good results.
![]() They aren't always easy to buy though, best off getting them online. |
Found 12v ones, solving that issue. Think though they are powered separately.
That's the idea! TC (you call it MOT) does not like it when the led bars go on with the high beam. This way I can just turn that feature off.
Already have a basic system. The reason I want to switch 2 + 2 is because it's convenient when camping an drains less power with only 2 switched on. The fact it is complicated doesn't scare me.
1A is ok apparently, thx! I will be posting a new version later on. Some good ideas though, which I can use! |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
Hi Zone30,
Do you have a link to the specification of the switches? It does not matter that you are using 3V LEDs as any switch that accepts 12v for the illumination will use a resistor to limit the current so that the voltage across the diode is correct. If you have to fit this resistor yourself, it is the same principle except you need a simple calculation to work out the value. I'm not sure why you have 3 ohm resistor, these would do little to limit current. I suspect the resistor should feed the 12v to a separate terminal on the switch to power the LED. If you changed S3 to an On-Off-On switch, you could implement this without diodes. I think this should achieve the functionality you want: . ![]() Cheers, Mark http://defender90xs.blogspot.co.uk/ |
image does not show...?
http://www.aliexpress.com/item/16mm-Green-...57160.html V2: without diodes + switches after relais. ![]() Click image to enlarge |
Experts: will this work?
This was my diagram. https://app.box.com/s/izg7f6qh5ijjmc4841kl
I think your schematic is OK. Your illumination can be run from the existing circuit, for example the cigarette lighter socket. http://defender90xs.blogspot.co.uk/ |
Thx for that, but I don't understand how, with s1 and s2 open, the high beam switch can turn the led bars on...
Damn this prooves to be quite difficult to understand! |
