Home > Puma (Tdci) > Blue Smoke |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2285 |
rule say: is oil going thru the valves, but before you take any action I suggest you check the oil level until the next service. Puma 110" SW
25th Jul 2010 5:46pm |
or turbo.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
25th Jul 2010 10:09pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1568 |
This blue smoke seems to be only on start up. Sounds like it has a miss fire. Think I might video it to show the dealer. Guess turbo would be an easy swap.
25th Jul 2010 11:07pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
are you waiting until the glow plug light has gone out before starting 2.4 90 XS
26th Jul 2010 9:35am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19690 |
Personally i always do this. Would this be what could happen? |
26th Jul 2010 9:43am |
yes unburnt fuel 2.4 90 XS
26th Jul 2010 10:14am |
Yes I have even tried putting glow plugs on twice doesnt have any affect on amount of smoke. I am also in the habit of waiting for glow plugs as I have only owned diesel landrovers.
I take this isnt a common problem then! |
26th Jul 2010 11:26pm |
Would I know if the glow plugs are broke?
26th Jul 2010 11:28pm |
I would have it in observation for a while to check if the oil level drops. Also check you have the right oil dipstick.
if you are keen on dismantling you could look if there is oil at the intake air hose after the turbo or intercooler. Puma 110" SW ............................................................. Earth first. Other planets later |
26th Jul 2010 11:32pm |
Checking oil in hose i can manage that. But how do I know if its the right dipstick???
26th Jul 2010 11:37pm |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 |
How do RobKeay. Mine was doing exactly what yours is doing. Lots of smoke on start up and then shaking about, missfiring. When it warmed up it was fine. It turned out it was a software update that had not installed correctly. . It didn't make any sense to me but it has been fine{touch wood} ever since.
Richard 1963 Series 2A truck cab 2008 110 SW |
27th Jul 2010 6:35am |
Nice one ill take it in and get it checke for updates!! Thanks for that I knew someone else would have the problem as well.
27th Jul 2010 7:09pm |
Well its all fixed. Software problem!!!! Theres no smoke and the engine is sound now.
13th Aug 2010 7:35pm |
2.4 90 XS
13th Aug 2010 8:29pm |
