![]() | Home > Puma (Tdci) > Blue Smoke |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2471 ![]() ![]() ![]() |
rule say: is oil going thru the valves, but before you take any action I suggest you check the oil level until the next service. Puma 110" SW
or turbo.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
This blue smoke seems to be only on start up. Sounds like it has a miss fire. Think I might video it to show the dealer. Guess turbo would be an easy swap.
are you waiting until the glow plug light has gone out before starting 2.4 90 XS
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20842 ![]() ![]() |
Personally i always do this. Would this be what could happen? |
yes unburnt fuel 2.4 90 XS
Yes I have even tried putting glow plugs on twice doesnt have any affect on amount of smoke. I am also in the habit of waiting for glow plugs as I have only owned diesel landrovers.
I take this isnt a common problem then! |
Would I know if the glow plugs are broke?
I would have it in observation for a while to check if the oil level drops. Also check you have the right oil dipstick.
if you are keen on dismantling you could look if there is oil at the intake air hose after the turbo or intercooler. Puma 110" SW ............................................................. Earth first. Other planets later |
Checking oil in hose i can manage that. But how do I know if its the right dipstick???
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
How do RobKeay. Mine was doing exactly what yours is doing. Lots of smoke on start up and then shaking about, missfiring. When it warmed up it was fine. It turned out it was a software update that had not installed correctly.
![]() Richard 1963 Series 2A truck cab 2008 110 SW |
Nice one ill take it in and get it checke for updates!! Thanks for that I knew someone else would have the problem as well.
Well its all fixed. Software problem!!!! Theres no smoke and the engine is sound now.
![]() 1968 1/32 scale Britains 109 Pick up. |
