Home > Puma (Tdci) > To Service or NOT to service
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I dont drive my landy often. Had 2 kids and the trips kind of stopped. Now that the youngest is 2 we are going on a Namibia trip to visit my brother in Windhoek, going via the kgalagadi.
My landy has done 41k km in total. In the past 12 months it's done 14k km.
It was last serviced in November 2013 by landrover due to the warranty still being an issue. The warranty is now over.
I was going to take it to our local indie in pretoria (Waynes 4x4) but he is so popular he is booked out till January Sad
Landrover is an extreme ripp off!!!!! and quoted R8500 for the 80k service..... I cant do that!!
Now it seems the 80 k service includes diff and gearbox oil changes.
Can I wait till January and go on our overland trip. It will total my km to 20k km in the past 12 months but i'll be over in time with 3 months.
What shall I do. Change at least the filters and engine oil myself and then take it to Wayne in January?
Post #371296 12th Nov 2014 5:58pm
If you are able to service and use genuine parts ... Why not ? Keep the receipt for the oil and filters
Careful if you decide to tackle the axles, xfr box and gearboxes though
Post #371300 12th Nov 2014 6:14pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Marius
Why not contact Walter at LRExtreme in Pta East? Way better indie than Wayne.
Btw...I service my Puma myself. Extremely easy and you know that is was done right. There are so many tips on servicing the Puma that you really can not go wrong.
Post #371312 12th Nov 2014 7:07pm
LR90XS2011
do it yourself dead easy with limited tools and cost very little compared to a garage, follow the guide on here I did and am happy that I did saving over £500 DEFENDER 90 TDCI XS,
Post #371333 12th Nov 2014 9:15pm
Not just saving you money but more importantly knowing it was done correctly. Thumbs Up
Post #371420 13th Nov 2014 1:00pm
Cheshire110
I'm a pretty hopeless mechanic and it's very doable DIY.
Including diffs, trans box, gbox, engine, filters etc,
There's good guides on here Cheers, David
Post #371457 13th Nov 2014 5:49pm
Marius
I see the sump plug of the engine needs replacing. What about the plugs for the rest?
Post #371559 14th Nov 2014 4:08am
LR90XS2011
the engine sump plug has a parallel thread and rubber seal and that is why it is recommended to be replaced, the axles are reusable and tapered threads, the gear box and transfer box are also reused DEFENDER 90 TDCI XS,
Post #371560 14th Nov 2014 6:30am
LR90XS2011
martinks post and subsequent thread on the subject
http://www.defender2.net/forum/topic8707.html DEFENDER 90 TDCI XS,
Post #371561 14th Nov 2014 6:31am
Marius
So after digging around I made the following lists from various sources (This site; Topix; SA 4x4 forums).
Which oil in each category would be preferred or rated best?
Engine Oil:
5W/30 – WSS–M2C913–B
WSS–M2C913–C
Castrol Magnatec 5W-30 A1 Fully Synthetic
Puma 6 Speed Gearbox (MT82) : 2.2l (Service fill); 2.4l (Dry fill)
Castrol BOT 130M (SAE75W-90. API GL4)
Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF
Castrol BOT402
MTF 94
ATF Dexron D2 or D3
NB!! Do not fill the Gearbox until the oil flow out of the Filler hole. The filer hole is NOT at the full mark as we used to on ie the R380. (Land Rover had to send the Dealers a Service Bullitin (SSM34407) to highlight this)
Transfer Case: 2.3litres
Castrol Syntrax 75W–90
Texaco Multigear 75W–90R
API GL4 or GL5
MIL-L-2105 or MIL-L-2105B
Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil
Front and Rear Diffs: Both is 1.6litres
Castrol EPX 80W–90
Texaco Geartex EP85W–90
Post #371588 14th Nov 2014 10:08am
jst
i would just change engine oil and filter then get it done Jan time when they can book them in. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #371593 14th Nov 2014 10:33am
MartinK
Re: To Service or NOT to service
That's what I would do...
Seconded...
Mine's due now (well, last month actually). However it's only done 8000 easy miles since the last (dealer) service. As I won't be using her much in the next 3 months, I'll be leaving it just now, and getting it done in Spring before still doing any major miles.
I did an interim service myself last year. Warranty's expired now, so I will be doing some myself, and some by the local Indie... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #371610 14th Nov 2014 1:00pm
